[Z06] Oil Temps - normal?
Old Jun 16, 2004 | 10:59 AM
C6~Missle's Avatar
C6~Missle
Default Oil Temps - normal?
I was out running some errands this morning.. outside it was 81 degrees.
I have 400 miles on the Z and I was seeing temps as high as 230.
I am driving it fairly easy.. I don't remember temps this high on my 99...
Is this normal...
The temps do come down to about 220 or so... but stays up there for awhile..
mike
Old Jun 16, 2004 | 12:15 PM
robz's Avatar
robz
Default Re: Oil Temps - normal? (C5~Missle)
on 90 dgree days I see 240.
Old Jun 16, 2004 | 12:39 PM
C6~Missle's Avatar
C6~Missle
Default Re: Oil Temps - normal? (robz)
OK... thanks... whew.. I figure the temps might be higher than usual due to the fact the engine is still new and very tight.
Just trying to make sure its not only me...
Old Jun 16, 2004 | 02:01 PM
08msmZ06's Avatar
08msmZ06
Is this normal...
mike
Mine's the same; it's normal.
Old Jun 16, 2004 | 02:17 PM
Pumba's Avatar
Pumba
Mike,
I was up at the Corvettes on the Isthmus event in Wisconsin Dells last Saturday and had an oil temp of 241 degrees F during an afternoon scenic drive. Ambient temperatures were in the low 90s.
Old Jun 16, 2004 | 02:29 PM
z-u-later's Avatar
z-u-later
Default Re: Oil Temps - normal? (Pumba)
On 95 degree days I "Z" a 230 oil temp. At start up I wait at least till 120
Old Jun 16, 2004 | 06:16 PM
MaverickC5's Avatar
MaverickC5
700 miles on mine. It was ~95 here today. Temps varied btw. 217 and 230 one warmed up. That is about 5 - 7 more than my '01 coupe. Seems normal to me.
Old Jun 16, 2004 | 08:40 PM
racer959's Avatar
racer959
Default Re: Oil Temps - normal? (MaverickC5)
same here
Old Jun 16, 2004 | 08:51 PM
ZO6Les's Avatar
ZO6Les
Yep, about right. I have a 178 degree thermostat and that seems to help the oil temp a little. Just checked - ambient 90 degree's, radiator 190 and oil 217.
Les
To Oil Temps - normal?
