[Z06] Hurst shifter noise...inner boot??
Old Jun 18, 2004 | 10:25 AM
Vettdaddy's Avatar
Vettdaddy
Default Hurst shifter noise...inner boot??
Previous thread, re stiff, takes a little getting used to.. really precise on track, love the 3-2 shift.
The driveline noise increase is dramatic, has anyone got a solution to fitting the inner boot a little better? Tried the reverse (method 1 in the instructions) quite a gap, prefer not to cut it.
Maybe a little silicone ? Additonal gasket rubber?? Ant ideas or previous solutions?
Old Jun 18, 2004 | 02:49 PM
HummelS's Avatar
HummelS
Default Re: Hurst shifter noise...inner boot?? (Vettdaddy)
Some guys have used a tennis ball, cut in half and slipped over the shaft. Also, the stock **** is prone to rattle; I used a Momo & had virtually no driveline noise.
Old Jun 18, 2004 | 05:33 PM
Threed's Avatar
Threed
From: GOCC - Rebels Without A Clue Santa Barbara, CA
Default Re: Hurst shifter noise...inner boot?? (thevettenet CA)
Another way is to buy a 2" rubber pipe cap and drill a 5/8" hole in it.
To Hurst shifter noise...inner boot??
