[Z06] Upper rear a-arm chassis weld failure
Old Jun 21, 2004 | 07:25 PM
drbenne's Avatar
drbenne
Default Upper rear a-arm chassis weld failure
I have 2001 Z06 used exclusively for racing that we recently found the rear upper a-arm weld to the chassis had started to separate. The car has not been hit in the rear. Anyone heard of this before and, if so, is there a GM repair procedure recommendation. Glad we saw it during a suspension modification and not at 145mph on the track.
Old Jun 21, 2004 | 07:44 PM
Painrace's Avatar
Painrace
Default Re: Upper rear a-arm chassis weld failure (drbenne)
Has the car been hit, at all? Are you using race tires. After many years of racing I can tell you impacts in one area show up all over. Race tires also put a big strain on the chassis especially if the car gets airborne. I suggest if it is a problem on one side the other side is also a problem. In the late 70's-early 80's the first thing we did to build a race car was reweld EVERYTHING!
Old Jun 21, 2004 | 07:56 PM
drbenne's Avatar
drbenne
Default Re: Upper rear a-arm chassis weld failure (Painrace)
There has been some light front contact, but nothing too major. Thanks for the recommendation on weld everything. I am planning on having all the rear a-arm connections welded and reinforced with some welded gussets. Scared the heck out of me to think that I may have gone out next month and had a rear suspension failure.
Old Jun 22, 2004 | 12:26 AM
rgregory's Avatar
rgregory
I remember someone posting a while back about this happening can't remember if it was front or rear. It was a street car I believe.
Old Jun 22, 2004 | 12:28 AM
Bill Dearborn's Avatar
Bill Dearborn
Default Re: Upper rear a-arm chassis weld failure (rgregory)
Several years ago there was some number of people who reported the problem of broken suspension mounting point welds. Not sure but it may have been in 99 or 2000.
Bill
Old Jun 22, 2004 | 10:01 AM
wamara's Avatar
wamara
Cruise-In II Veteran
Something similar to this happened to Batmobile a few years ago; if I recall correctly, it was one of the shock tower mounts....
Old Jun 23, 2004 | 05:00 AM
TTRotary's Avatar
TTRotary
Default Re: Upper rear a-arm chassis weld failure (wamara)
Correct, as I recall. But he lives in the Caribbean, which is a brutal climate for metals given salt+heat+huimidity.
dbenne, are you running coilovers?
To Upper rear a-arm chassis weld failure
