[Z06] Starting the ZO6
Old Jun 28, 2004 | 03:05 AM
jimmy2004's Avatar
jimmy2004
Default Starting the ZO6
Do you guys have a rough start-up in the morning? whenever i turn the key, it takes a while for the engine to kick over. this isn't an issue on our '98 Pace Car, it starts right up. You think it's the camshaft(stock)? thanx
Old Jun 28, 2004 | 04:16 AM
CAPN17's Avatar
CAPN17
Default Re: Starting the ZO6 (jimmy2004)
Z fires off as soon as the key and clutch saftey are in the upright and locked position. Very little cranking to fire off.
Old Jun 28, 2004 | 09:03 AM
ZO6Les's Avatar
ZO6Les
Mine started fine stock - still does heavily modified. I suggest a trip to the dealer if it is under warranty.
Les
Old Jun 28, 2004 | 09:19 AM
stingray454's Avatar
stingray454
Something isn't right - have the dealer check it out. Mine always starts right up - like within a second or two of turning the key.
Old Jun 28, 2004 | 09:28 AM
Corvette SSX's Avatar
Corvette SSX
St. Jude Donor '08
No problems starting mine. Fires right up every time.
Old Jun 28, 2004 | 10:07 AM
dilly03's Avatar
dilly03
I just recently noticed the exact same thing when I first start it for the day.
I also noticed at appoximately the same time the starting issue developed, my fuel pump became louder. I used to only faintly hear the fuel pump, but now it is clear as ever.
Hopefully, someone hear knows what's up.....
Old Jun 28, 2004 | 11:36 AM
BlackZ06's Avatar
BlackZ06
I'd check to see if you have a DTC set (Diagnostic Trouble Code). The PCM uses the camshaft position sensor to determine when a cylinder is on its compression stroke for firing the spark plugs. If the camshaft position sensor has failed, the PCM then uses the crankshaft position sensor to determine (along with some other inputs) when a cylinder is in compression. This takes more engine revolutions, so starting may appear to take longer. The failure of the cam position sensor will set a DTC.
Old Jun 28, 2004 | 05:49 PM
Arizona Z's Avatar
Arizona Z
Fires right up, even with all the mods. Maybe you should have someone check it out.
Old Jun 28, 2004 | 05:59 PM
smook's Avatar
smook
Starts as I demand it!!!
Great car! Always start it with the clutch in.
Cheers !
Bill.
[Modified by smook, 6:17 PM 6/28/2004]
Old Jun 28, 2004 | 06:15 PM
Paul4137's Avatar
Paul4137
Default Re: Starting the ZO6 (smook)
I have a c5 vert had the same problem they replaced the starter relay, starts right up ever time now.
To Starting the ZO6
