Headlight Delay...
Old Jul 8, 2004 | 08:53 PM
Lex Luthor's Avatar
Lex Luthor
Default Headlight Delay...
I post this before and got no hits. I know there was a thread on this somewhere but I cannot find it.
When I turn on the main lights it used to take several seconds for the lights to pop up. It progressively took longer and longer. Now It takes up to a minute after switch the lights in the on position for the lights to pop up. I've tried switching on/off rapidly to see if the lights engage but it wants to sit it out until IT'S ready to pop up.
Like I said, I saw someone that had the same situation and resolved the issue. Let me know if any of your guru's have any insight. Thx
Old Jul 8, 2004 | 09:27 PM
Lex Luthor's Avatar
Lex Luthor
It's a '98 Vert...BTW.
Old Jul 9, 2004 | 12:45 AM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Mine jusstarted not coming up until you turn the switch twice! Very annoying, maybe they're related! but TTT for yah, and good luck
Old Jul 9, 2004 | 01:36 AM
Wicked98's Avatar
Wicked98
Default I got the same symptom
Yup I have had it happen a few times. it's intermintant with mine though. some times it's instant sometimes it's a ..... "BIT" ... how shall we say..delayed? no idea what causes it either
Old Jul 9, 2004 | 02:00 AM
Lex Luthor's Avatar
Lex Luthor
Mine has gotten real delayed. And more everytime.
Old Jul 9, 2004 | 09:33 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Been there. Done that!
You have a broken wire in the turn signal/speed control/turn signal/head light switch wiring harness. This harness runs from the lever assembly down through the steering column and plugs into another wiring harness at the base of the insturment panel.
Every time you move your tilt wheel assembly you bend this harness. After a while some of the wires begin breaking apart inside the wire's insulation.
Next time your headlights (or turn signals, speed control, dimmer switch) acts up, move your tilt wheel up and down a few times. If it magically starts working again you've found the problem.
It's a fairly easy fix. (2 hours) About $125 for the part. The harness/stalk assembly is made in one piece.
Tom
Old Jul 9, 2004 | 11:36 PM
George8211's Avatar
George8211
I've never seen any kind of Forum share more info than is shared here
Old Jul 10, 2004 | 04:12 AM
Lex Luthor's Avatar
Lex Luthor
Tom
Thanks for the input. I'll give that a try!
Hail to Zora :flag
CF is Vette Meca!
Old Jul 10, 2004 | 11:00 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Great stuff. This is one for the archives for sure. Thanks for the post.
To Headlight Delay...
