Installing exhaust
Old Jul 9, 2004 | 01:25 PM
noel48's Avatar
noel48
St. Jude Donor '14
Default Installing exhaust
I'm getting the Corsa Touring installed next week.Do I need to adjust/change anything in the engine?Will tranny(A4) be OK?
Old Jul 9, 2004 | 01:28 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Nope, just bolt it on and go.
Old Jul 9, 2004 | 02:08 PM
1 BAD C5's Avatar
1 BAD C5
Just install it and that is all you have to do. But I warn you the exhaust mod is usually where it all begins. Then it is headers, heads & cam, etc.
Old Jul 9, 2004 | 02:11 PM
HummelS's Avatar
HummelS
They will need to drop the sway-bar to get the stock exhaust out without cutting it - undo the nuts & bolts that attach to the frame and it will just pivot out of the way. Make sure they retorque to specs when re-installing the sway-bar - 49 lb/ft for the bolts, & 70 lb/ft for the nuts.
Old Jul 9, 2004 | 02:14 PM
P51tj's Avatar
P51tj
Just bolt on and go!!!
Old Jul 9, 2004 | 02:21 PM
jrose7004's Avatar
jrose7004
Don't forget the X-Pipe!!
Old Jul 9, 2004 | 02:55 PM
jackj's Avatar
jackj
just plug and play & FORGET THE X pipe I went that way and it KILLED the sound of the exhausts, don't waste your $ on the X pipe!
Old Jul 10, 2004 | 12:44 AM
Mike04's Avatar
Mike04
Cat backs are great, they bring the engine noise alive with out having to do anything else....Although, they do make you want to mod something else!
To Installing exhaust
