[Z06] Heads/cam opinions...???
Do you know which AFR heads and modest cam are being used? I read about a new one, is it the 205 or 225 on their webpage?
I'm having a 224/228 114 cam with Kooks headers being installed at LAPD as I write this. I already have the AFR 205 heads
I'll pick the car up late today or tomorrow with dyno results.
Maybe this will help with your decision
1. Cartech Heads/Cam
2. MTI Heads/Cam
3. AFR Heads/LG GX5(?) Cam
It seems the Cartech is by far the most expensive, then the AFR setup, then the MTI setup. Problem is that I've heard great things about all of them. Now if I could only see a dyno graph for each of them on MY setup we'd be all set!
If it was as easy as saying the more you spend on Heads/Cam the more power and better torque curve you'll get, but I have no wa of really knowing...
Thanks.
Also, bolting this stuff on your car without an LS1/6 edit makes it worthless. The car will need to be re-tuned for maximum performance and reliability. You will be very unhappy with the results of just bolting this stuff to your car. Even with an aggressive package, you might not make another 40hp without a proper tune, let alone another 100hp. Also Long tubes are a must (another $1000)...oh, and you will definately destroy the stock clutch within a 100 miles (another $1200).
So just for starters look at spending $7000+ to get another 100 SOLID REAR WHEEL DYNO'D RELIABLE HP. Also this will void any warranty on the motor, so you better choose a shop with a DAMN good reputation that has done tons of C5's with good referrals. An additional 100HP does nothing if the motor breaks in 1000 miles, which happened to a friend of mine...had to spend the same money twice.
I have the Long Tubes already and will get it done by a professional with LS1 Edit for sure. But why would they have to pull the motor?
You're right, $5,000 is what I'm finding, installed and tuned properly. The good new is that the stock heads/cam are worth around $1,000-$1,300. So the REAL money spent on this setup can be under $4,000 total, with a killer package, professionally done.
As far as replacing the clutch right away, i've been told otherwise. But I don't have experience with that so....
Also, you do not get 100RWHP from just H/C alone...you'll need a throttle body, Long Tubes, exhaust, upgraded intake (some of which you already have) and most likely a modified MAF, but I am inlcuding this within the $7k.
So, now you have an extra stock cam that is worthless, because anyone who is replacing their cam and is smart will not be using a stock cam. And your clutch WILL go...so the REAL money needed to be spent is $7000+. The most important piece of advice, when you do spend the $7k, do a lot of research on the tuner...there is lots of talk about making power, but you want to speak with 3 people who have had their car done at that particular shop. Don't worry about buying parts, just find a reputable tuner and let them do whatever they need, as long as they DYNO your car with the proven power increase.
- Cost is roughly $2800 for the AFRs and LS6 heads are worth $1000 (total $1800 once sold).
- Stock Z06 cams have been selling around $150 on Ebay.
- Xtreme (Tempe AZ) never mentioned having to pull the motor (but i could be wrong).
- They have also given me very close realistic numbers on the actual power. I do love the advice (although most of it I already know) so keep it coming!!
I am doing the swap in a week or two. I am using the AFR heads and cam. My cam will fairly mild as I want a sleeper, but I still expect about 60-70 RWHP.
Give Al or Shawn a call at LAPD. They will be glad to help you sort through a lot of this.
