[Z06] trans noise?
Old Jul 12, 2004 | 01:10 AM
erikszr1's Avatar
erikszr1
Default trans noise?
does anybody else have a noise like a rumbling sound in neutral without clutch depressed and then when you push clutch down it goes away------sounds like just the sound of input shaft turning and then pushing pushing clutch down disengages trans from engine it stops? trans works perfect hope its ok, my zr1 sounds just like it also and i know all of those do it
Old Jul 12, 2004 | 01:16 AM
Mike04Z06's Avatar
Mike04Z06
My Z06 doesn't make that sound but when I put an aftermarket shifter on my 99 WS6 T/A it happened. Less insulation in the Z06 shifter (?) might make the noise more noticeable, I'm guessing its normal.
Old Jul 12, 2004 | 01:34 AM
erikszr1's Avatar
erikszr1
maybe im being too critical
Old Jul 12, 2004 | 03:01 AM
User 81424's Avatar
User 81424
That's the reason they video tells us to depress the clutch when turning off the car, it's keeps the noise from happening, I think it's the throw out bearing rattling, but not sure.
Old Jul 12, 2004 | 11:02 AM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Mine does it, no worries.
Old Jul 12, 2004 | 11:07 AM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Diddo.
Old Jul 14, 2004 | 12:26 AM
erikszr1's Avatar
erikszr1
Default trans rattle/rumble in neutral?
i guess i should watch video----so does anybody else hate these sounds--------i figured i would get away from these sounds my 91 zr1 made!
Old Jul 14, 2004 | 12:46 AM
erikszr1's Avatar
erikszr1
Default trans noise!
i would feel much better if at least a few more people said not to worry----please i take your guys word for it, i just need assurance
Old Jul 14, 2004 | 11:12 AM
t56gen3's Avatar
t56gen3
Don't worry, is normal.
Old Jul 14, 2004 | 11:52 AM
CAPN17's Avatar
CAPN17
It does it to all the Zs put your worries on the column lock or the gas gauge, not on normal worries. You are all right, sit back and wait for MOD fever to start, then worry about noises. like your bank account deflating.
Old Jul 14, 2004 | 12:17 PM
sakz06's Avatar
sakz06
I have been told by my corvette specialist that works on mine, that it is refered to as "power pulses". definitly sound bad, but race cars make noises (period)
To trans noise?
