Gas Gage Trouble
Old Jul 13, 2004 | 05:17 PM
doc1's Avatar
doc1
5th Gear
Default Gas Gage Trouble
My Gas Gage changes from 1/2 full to empty from empty to 1/2 full. I have no Idea how much gas I have. Is this a isolated problem.
Old Jul 13, 2004 | 05:32 PM
Actually a number of members report this problem. I had it with my '99 until they replaced the sending units in the fuel tanks. I have not had it happen to my '00. Sometimes it happens as a result of the sulphur content in the gas. Try switching gas brands and see if that helps.
Old Jul 13, 2004 | 06:18 PM
British's Avatar
British
I'm starting to have similar problems. Yesterday my gauge showed a quarter tank and the car started sputtering!
"Detergent" gasolines, such as Chevon with Techronâ„¢ seem to ease - but not completely solve - the problem.
Old Jul 13, 2004 | 06:47 PM
steve1173's Avatar
steve1173
Did you buy Shell, Chevron or Texaco in June. There was an article that the refinery it came from Motiva had too much sulphur & was ruining gas senders & that they will pay for the repairs.
Old Jul 13, 2004 | 07:22 PM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
I had mine completely show empty 3 times last year...never since.
Old Jul 13, 2004 | 08:52 PM
British's Avatar
British
Really? Do you have a link for this?
Old Jul 13, 2004 | 08:58 PM
bobsY2Kvette's Avatar
bobsY2Kvette
Nopwe, Lots of people report this problemo. I had it myself till a buddy of mine who works for a chevy dealership found a bullitin on it and made some software upgrades to my pcm. Since Then
Old Jul 13, 2004 | 09:17 PM
steve1173's Avatar
steve1173
No Link was in the newspapers, you have to give Shell a call & they send you the paperwork. Motiva refines those 3 brands in the south.
Found this with a google search
Class Action Filed in La. www.silmas.com
Defective Shell Texaco Chevron Fuel Silvestri & Massicot (800) 951-3400
Here is another http://www.aiada.org/article.asp?id=15452
Old Jul 13, 2004 | 10:06 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
St. Jude Donor '05-'06
Check your COmputer code and see if you are get either one of these codes, P1431 or P0461
To check your codes Turn the key to the ON position, but don't start the engine. Clear any present messages by pressing the RESET button. Hold the OPTIONS button down, and press the FUEL button 4 times. This will get you into the CODES section of the DIC. The computer will automatically display all the codes your car has created. It will cycle through each code every 3 seconds. Any code that ends in H is a history code (something that has occured in the past) but is fine now. Once the computer has finished going through all of it's codes, press RESET to enter Manual Configuration mode. It should start with a module and show "NO CODES" or "# CODES".
Also welcome to the fault fuel gauge club I have had a major problem within the past few weeks.
Old Jul 13, 2004 | 10:55 PM
EscapePod's Avatar
EscapePod
Zilla, did you get the part numbers for the newest sensors yet?
Old Jul 13, 2004 | 11:57 PM
Zilla's Avatar
Zilla
No yet, the dealer is still waiting for the parts. Hopefully later this week or early next week.
Old Jul 14, 2004 | 06:05 PM
EscapePod's Avatar
EscapePod
Please keep us posted. My sensor(s) is toast, and I'd like to try the new ones. My '01 is out of warranty and I just want to have to change them one last time.
Old Jul 14, 2004 | 06:11 PM
Colbalt Blue's Avatar
Colbalt Blue
I have a problem with my Gauge, it that it will go from full to empty; however, when I stop and put the car in Park the gauge returns to full or whatever the correct reading should be. Had this exact same problem with my Grand Prix, the fix was to reflash the PCM.
JMTCW,
Old Jul 14, 2004 | 10:55 PM
DTWC5's Avatar
DTWC5
Cruising
I tried this also and it worked most of the time. I still would like the new part number also.
To Gas Gage Trouble
