Need help on "Easy entry"
Old Jul 13, 2004 | 10:57 PM
vette0202's Avatar
vette0202
Cruise-In I Veteran
Default Need help on "Easy entry"
I just bought a used 2002 C5 and it came with no FOBS but with a clifford alarm. I bought 2 FOBS off e-bay so that I could use the Factory alrm and not the Clifford. I just trained one of my FOBS and it unlocks and locks the doors with no problems. BUT when I unlock the car the drivers seat moves all the way back everytime I unlock the car. Then I have to manually adjust it for myself. I did go into the options and turn off easy entry but it still does it. Any ideas on how to turn this feature off?
Also in my 98 C5 my FOB had a switch to turn on/off passive alarming. Does the 2002 C5s have passive alarming?
Old Jul 13, 2004 | 11:00 PM
Vetteguy53081's Avatar
Vetteguy53081
Look thru your manual. I believe there is a memory option to cancel your seat from going back each time.
OR
Consult dealership. They should be of some use to us Vette owners once in a while instead of raping out pockets each visit.
Old Jul 13, 2004 | 11:01 PM
PetalBombC5's Avatar
PetalBombC5
Do you have memory seats? If you program the seats to your key, they will readjust when you put your key in the ignition and close the door
Old Jul 13, 2004 | 11:33 PM
Also, if you have turned off the easy entry option accessed through the DIC and it still moves, you may have some problem that will need more help than I can give you. Good luck getting this figured out.
BTW, the '02's do not have passive arming.
Old Jul 13, 2004 | 11:50 PM
vette0202's Avatar
vette0202
Cruise-In I Veteran
Just found a thread stating to try to set both memory 1 and 2 to my driving position.
Wow they got rid of the passive arming. Wonder why? That was one of my favorite features in my 98. What a bummer.
Old Oct 10, 2004 | 02:03 PM
boatboatboat's Avatar
boatboatboat
Do the 04's have passive entry?
I can't find mention of it in the Owners Man. so I assume they do NOT have passive entry?
To Need help on "Easy entry"
