What gas (octane) do you all use?
Old Jul 16, 2004 | 04:57 AM
BigMacNYC's Avatar
BigMacNYC
Default What gas (octane) do you all use?
Just curious to know with the high gas prices?? The manual states you can use 89 or higher. For performance use 92 or better So what do you all use???
Old Jul 16, 2004 | 05:02 AM
CORTVET's Avatar
CORTVET
From: Putting a 50¢ sticker of the U.S. Flag on a $50,000 import does not make one a patriot.
91 most of the time, but I will put 101 in sometimes too. nothing under 91 for my vette.
AZC5
BTW- 92 is not available here in AZ
Old Jul 16, 2004 | 05:39 AM
NPh2005's Avatar
NPh2005
I use 93, but just because that is what is available at a gas station that I frequently use. I would use anything form 91-93 octane. Would probably run fine on less octane, but I don't intend to find out.
Old Jul 16, 2004 | 06:01 AM
c4vette92's Avatar
c4vette92
St. Jude Contributor
i use sunoco 94 octane
Old Jul 16, 2004 | 06:06 AM
Red C6 Z06's Avatar
Red C6 Z06
St. Jude Donor '05 '09
I'm surprised that you find it runs fine on 91 (even though the owners manual implies or says to use it). With that 10.1:1 comp ratio (Z06 is 10.5:1), I was surprised to see that the owners manual didn't require 93. What your elevation? Higher elevations can get away with less octane since they are starting with a lower air pressure. I use 93 and it has never seemed to balk.
Tom
Old Jul 16, 2004 | 06:42 AM
IMQUIK's Avatar
IMQUIK
87!
Old Jul 16, 2004 | 06:59 AM
CORTVET's Avatar
CORTVET
Tom
You can not buy higher than 91 here in Phx. at the pump most of the time. Our ratings are 87, 89, or 91. There are like 10 speciality stations in Phx. that I know of where you can buy higher than 91 octane at the pump. At those stations, the options are usually 100 or 101. Expect to pay $5 a gallon for anything over 91($1.95 today) here.
We are at about 1,117 feet and with a population of 1.3 million(just in Phx, not surrounding cities), 10 stations is a very small niche.
I think it sucks, but the only thing I can do is move. I don't think I will be doing that though. I will just be jealous of all thoes who can buy 93 an 95 easily and cheeply!
AZC5
Old Jul 16, 2004 | 07:23 AM
Tom/99's Avatar
Tom/99
93 octane
Old Jul 16, 2004 | 07:31 AM
Blue Lion's Avatar
Blue Lion
93 octane. I waited a long time to get my Vette and I'm not about to put anything but the best in it.
Old Jul 16, 2004 | 07:40 AM
Tim T's Avatar
Tim T
93 octane Shell or 94 octane Sunoco
Old Jul 16, 2004 | 07:42 AM
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
93 here... next grade down is 89
Old Jul 16, 2004 | 07:50 AM
Wah's Avatar
Wah
93. It's only ~10 more cents per gallon from 89. In a 20-gallon fill up, it only costs $2 more. Ain't worth mulling it over.
Old Jul 16, 2004 | 08:06 AM
eddie44's Avatar
eddie44
St. Jude Donor '03
with AZC5. 91 is all we can get here in AZ. I have gone to strictly Chevron to solve the gas gauge problem and it seems to have worked.
Old Jul 16, 2004 | 08:48 AM
bobsY2Kvette's Avatar
bobsY2Kvette
I tell ya, I wouldnt run anything less than 93 in my A4. I once found myself in a position where I HAD to put in 89 (almost empty, only station nearby, and they were out of super) I hated the way the car ran It was like someone had reached in and ripped out 50hp. When it comes to the Motion Lotion, Gimme the best you got. 4 things in this world you should never compromise on.....Cars, Bourbon, Fuel, and Broads
Words of wisdom from Sensei Bob.....Class dismissed
Old Jul 16, 2004 | 08:53 AM
JCGRCYA's Avatar
JCGRCYA
St. Jude Donor '06
Nothing less than 91. Haven't really looked for a local station that carries anything higher, or whether it's even available in California. Anyway, I waited a long time to buy my Vette, so I'm not about to get cheap on the gas.
Old Jul 16, 2004 | 09:13 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Whatever Premium Gas I can find at Mobil or BP (Amoco).
For the amount of driving that I do (7 miles per day) the added cost is nothing...
Old Jul 16, 2004 | 09:35 AM
Groovepusher Sly's Avatar
Groovepusher Sly
Ooooh! That's good gas. Can't get that around here any more. There used to be a Sunoco here that had the 101 octane, it even smells different from regular gas.
I use BP (formally AMOCO) premium. I guess I'm dating myself calling it premium instead of using the numbers.
Sly
To What gas (octane) do you all use?
Old Jul 16, 2004 | 09:40 AM
Elite Engineering's Avatar
Elite Engineering
Supporting Vendor
St. jude Donor '14
91 here in Colorado
Old Jul 16, 2004 | 09:49 AM
Lex Luthor's Avatar
Lex Luthor
Aluminum Can's and banana peels. I have Mr. Fusion.
Old Jul 16, 2004 | 09:51 AM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
93, if there's a gas station with 92 i keep on driving, and NEVER 91 or 89, maybe i'm just paranoid, but i'd like to see the odo. read 200k some day, at this rate it'll be in four years!
