Towing Question
Old Jul 19, 2004 | 09:37 AM
SSR's Avatar
SSR
Default Towing Question
I'm having my car towed for the first time. Called Roadside Assistance and asked for a flatbed towing truck. Oh, the car is being towed to the dealer because it's completely dead.
1) What are the odds that it won't be a flatbedded towing truck?
2) Will the other kind be okay or do any harms to the Vette?
Thank you.
Old Jul 19, 2004 | 09:57 AM
bobsY2Kvette's Avatar
bobsY2Kvette
Thank you.
Flat bed is the only Viable option. Its a rearwheel drive vehicle and if it is lifted high enough from the rear, The nose will drag the ground. Insist on a flatbed and if they show with somthing else refuse the tow. But then again....If you need a paint job....Play "Mickey the Dunce" And after they scrape the hell out of it make their Insurance company paint the car!
Old Jul 19, 2004 | 10:05 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Flatbed or no towing. If they lift the front the rear wheels will turn the transaxle and that is not a good thing. If they lift the rear the nose will not last grinding on the pavement. But if you called for a flatbed you should get one. Most towing companies out there have them now. Second though maybe the nose wouldn't hit. So If they get the rear off the ground you probably be OK. Others will chime in if there's a problem I am sure.
Old Jul 19, 2004 | 11:17 AM
CE2004's Avatar
CE2004
If the tow truck driver has a couple of boards, they will prevent your vette from dragging. Either way they pull it on, boards will be needed to save them from scuffing your nose. I'm sure you'll be fine...
I guess you decided not to replace the battery yourself?
Old Jul 19, 2004 | 11:35 AM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Default Flatbed only
Why not see if it's the battery first so that you can avoid towing. Otherwise I would suggest to only use a flatbed, there is no other way to safely transport a Corvette. And make sure that they are careful not to scrape under the nose or rocker panels when loading and unloading your Vette. Maybe a tip will help.
Good luck.
Old Jul 19, 2004 | 12:17 PM
SSR's Avatar
SSR
Thank you for all the responses. The flatbed showed up. And for some reason, was able to get my car started. For those that haven't read my other post. My car all of a sudden wouldn't start, tried to jump it a couple of times and it wouldn't turn over.
Anyhow, i'm thinking of taking my car to NTB to have them check the battery voltage and alternator. Then probably will take the car to the dealer and leave it there. The car is still under warranty, a 02 with about 28 thousands miles to it.
Now i'll have to go to the archives to read up on battery before leaving.
Thank you again for all the suggestions and thoughts.
Old Jul 19, 2004 | 12:33 PM
CE2004's Avatar
CE2004
There are -many- messages on this forum regarding battery problems. The 2004's got another different battery, to try to address the battery failures of prior model years. Since batteries are pro-rated, and your car is 2-3 years old, just spend the $60 for a new battery.
Don't chase the problem around with these retail outlets while some slacker hooks up a load-tester to your car.
According to my battery catalog, it's a group 75 battery in your 2002 Corvette. Just go buy one at any local auto parts store, or even Walmart or Target. Put it in yourself, & crank it up. I hate to see you do without your car while it sits in the dealers lot when you haven't eliminated the dead battery. Since batteries are pro-rated, they will most likely charge you for a new one anyway.
Old Jul 19, 2004 | 01:08 PM
I would insist on the flatbed. This car sits way too low to tow it any other way.
Old Jul 19, 2004 | 01:18 PM
Doo's Avatar
Doo
St. Jude Donor '03 & '06
Old Jul 19, 2004 | 01:48 PM
TheJackel's Avatar
TheJackel
I had acid leak problems with my battery and had it replaced. The GM one is junk (JMO, no flames please)
Good luck on it.
Old Jul 19, 2004 | 02:07 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I agree with most of what CE2004 said - except that the only type of battery that you should be considering is an AGM (absorbed gas mat) battery, also known as a gel filled battery. The standard P.O.S. that you would buy at Wal-Mart or Target has the serious potential to spew electrolyte (leak). Directly underneath the battery tray is the electrical harness for the underhood and the computer. When that acid starts leaking, you could be facing damage in the $4K range.
Don't spend $60 - spend $100 at Costco or Pep Boys and get yourself an Optima Red Top 75/35 or a 34/78. I wouldn't let GM put another leaky Delco in my Vette !
Old Jul 19, 2004 | 04:40 PM
CE2004's Avatar
CE2004
Good points.
Although millions of lead-acid batteries are powering millions of vehicles on our highways, and millions of them don't leak. There are certain operating conditions that would cause a lead-acid battery to leak. Those conditions can occur on -any- vehicle. However, you certainly bring up a good point about the electronics under the battery den. A gel cell battery would definitely help to protect those electronic components under the battery den. For the extra $40-$60 for a gel-cell, it's definitely worth the peace of mind...
I think we'll both agree - replace the battery yourself to possibly avoid the rollback ride, and any dealer service department delays. If I take my car in for service, I'm going to try to eliminate as many possibilities as I can, myself - before I turn it over to a service department.
Old Jul 19, 2004 | 06:00 PM
blacksedan87
Good points.
I've had dozens (literally) of lead-acid batteries, and a surprising number of them DID leak, but it was not as critical as the Vette application. the metal tray below the battery took the brunt of the damage, in fact you can still buy mats to place below the battery to absord some of the acid. But the point is the damage to the electronics below.
The point of avoiding the dealership and the tow - I agree 1000%! Only under the most serious situation where no other possibility exists - would I have my car worked on at the dealer, and towed in. In the case of the originator of this thread - I would have attempted to exhaust all of the possibilities before resorting to the dealer - and I have a GOOD relationship with the dealer's service department!
To Towing Question
