Does anyone know where I can get one of these? Hurst use to make them years ago and I love the looks of it. It fits perpendicular to the shift and fits the contour of your hand, great for power shifting with no chance of a slip.
Stu's is an awesome custom. Mr. Gasket, distributor of Hurst products, sells lots of the kind you're looking for. Check out the ones at the link below. You need to page over to page 12 and 13 - just click on next ti' you get there.
They are sweet but I remember having one in Massachusetts years ago and in the summer they can get REALLY HOT. Since I now live in the middle of the Sonoran Dessert I think I'm going to pass as much as I hate to. I also have a 'vert and I think I might brand the palm of my hand with "Hurst" if I leave it parked in the sun with the top down which I do a lot.
I could be wrong but I don't think they are selling with the right thread pattern. Shouldn't it be a 9/16" 18 thread? The one above is metric and probably wouldn't fit. I guess you could tap it to the right size but that means buying a tap. My .02
I luv the T-handles also and had a heck of time locating one. Found one at a fleamarket/swap meet for 10.00. I drilled out and retaped the mounting threads to 9/16X18. Then I filled in the Hurst emblem and put 5 coats of Torch Red and 3 coats of clear on it. Turned out awesome, and I'm always getting comments on it. I guess because it's a bit unusual.
B&M also has one if you want to match your Ripper. I got one, gave it to the woman's father to have it tapped and they screwed it up. :mad Now I have to get another one.
I went to a speed shop and bought a Hurst T handle, made sure the thread size was 3/8" or 7/16", brought it home drilled it out and tapped it 9/16" - 18. As far as I could find they don't make one with the proper thread size.
