Part # for front DRL
Old Jul 20, 2004 | 03:59 PM
jroman's Avatar
jroman
Default Part # for front DRL
The last time (and 1st time) I changed a front turn signal lamp, I didn't write down the PN of the lamp. Had to pull lamp (no easy job) to get #, then drive to parts store, yadda yadda. Anybody got the PN handy so I can cut a step and just have to go in once ??
Thanks in advance.
Old Jul 20, 2004 | 04:16 PM
CE2004's Avatar
CE2004
Same as parking/turn signal light which is a 4157NA and probably only available in a Long-Life version. 4157NALL if you're dealing with Wagner or Sylvania...
Old Jul 20, 2004 | 04:20 PM
pk2401's Avatar
pk2401
St. Jude Contributor
Did you want the lamp or just the bulb.
The bulb: 9442399
Lamp RH: 10301356
Lamp LH: 10301357
Someone want to double check?
Old Jul 20, 2004 | 05:06 PM
VETLAGD's Avatar
VETLAGD
St. Jude Donor '06
4157NA... Just changed my this weekend. Easiest to go through from underneath the car....
To Part # for front DRL
