Question re: emblem on back deck
Old Jul 26, 2004 | 05:39 PM
mrgil's Avatar
mrgil
Burnout
Default Heat Gun??
Originally Posted by eddie44
If you haven't removed it yet, use a heat gun or hairdryer on high. If you've already done it then use googone to remove the adhesive.
Plaese oh please don't use a heat gun it will remove the paint... Mine is over 1000 Degrees.
mrgil
Old Jul 26, 2004 | 05:55 PM
Joezone914's Avatar
Joezone914
mrgil
I saw that post from Eddie44 about the heat gone i did not even suggest it to my friend. I would not have wanted him to mess up his new car!
Old Jul 28, 2004 | 10:35 AM
mojoman's Avatar
mojoman
I used a hairdryer to warm it up, and then dental floss to get under the emblem. Came right off withh little effort. Wiped it with Goof Off, and washed and waxed the spot. NO notice it was ever there!
Old Jul 28, 2004 | 10:36 AM
mojoman's Avatar
mojoman
Old Jul 28, 2004 | 02:12 PM
TIKTGTR's Avatar
TIKTGTR
Originally Posted by thevettenet CA
You can use WD-40 to clean up the leftover tape after it's off. Mineral spirits will also work well.
Thats what I did after I used dental floss between the emblem and car. Used a little NXT after and looks great!
