Hood light not working?
Old Mar 16, 2015 | 07:43 PM
gotti65's Avatar
gotti65
Originally Posted by 2FAS4UU
I believe that during a time frame with earlier models, 97'-99' and maybe 00'. The earlier housings, like in my 99', takes the 561 'rigid loop' bulb and later models take the regular #561 bulb. My guess is you have the wrong bulb !!
Go to flea-bay and type in, 561 'rigid loop' bulb and you'll see the different variations of the 561 bulb. Good luck !
Well I have a 2002 and tried the Regular 561 and it seems not long enough..Wish I had a pic of the fixture with the light bulb installed but ur year would be a rigid bulb and would be no help to me..Thanks anyways
Old Mar 16, 2015 | 11:26 PM
2FAS4UU's Avatar
2FAS4UU
If you post a pic of your housing, I am sure we can get the correct bulb issue resolved.
P.S. The #561 bulb also comes in different lengths,i.e., 36mm, 39mm, 42mm, etc.
Old Mar 17, 2015 | 05:53 AM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
This is where I bought the bulb for my 2002 Z :
http://www.corvettepartsworldwide.co...lb_p/38492.htm
Old Mar 17, 2015 | 06:49 AM
VettesGoneWild's Avatar
VettesGoneWild
My hood light was disconnected when I bought mine and thought perhaps there had been a power drain and was intentionally left off. I suspected this could happen if it became stuck on when the hood was closed. Figured it probably didn't provide much useful illumination anyway. However I do like everything working on my car so will live on the edge and hook it back up.
