Run Flats vs. Regular Tires
1. Cell phone and a AAA card - problem is sporadic cell phone coverage especially away from metro areas and waiting by the side of the road for up to several hours for your friendly and gentle tow truck driver.
2. Purchase the kit that comes standard on a Z06 - about $450. consists of small compressor with cigarette lighter plug, plug kit, etc.
3. Make your own kit. I bought a small Campbell-Hausfield compressor at Wally World for $10, bought a flat repair kit from Griot's Garage with a pliers, plugs and insertion tool with a bag on a closeout deal for $20. I added a flashlight, a pair of MechanixWear gloves, an old shower curtain/drop cloth to lay on or kneel on and a good quality digital air pressure gauge. My total outlay was well under $100. I still keep my cell phone handy for just in case....
I would not recommend using the fix-a-flat goop in a can. It will make a mess of the tire pressure sensor and the inside of the tire.
None of these solutions should be considered permanent fixes. Once you've repaired your flat, you'll need to seek professional "hot patch" repairs. Of course none of these solutions, except for the first one will address a blow out or a large puncture either to the tread of the sidewall. In those cases - a tow truck and a replacement tire is the course of action required.
EEL
runflats. They suck!
You will not know handling at all until
you change those run fats.
They are a terrible choice on any car.
And expensive as well. They SUCK.
That means they are HORRIBLE.
Did I say runflats are HUGELY TERRIBLE!
Save yourself a ton of money. Go to Wal_Mart and get a 12 volt compressor, a collapsable lug wrench, and a tire patch kit with a tee handle.
You can also get a great little jack that takes up very little room for $50.00
http://forums.corvetteforum.com/showthread.php?t=867116
Consumer surveys have shown that Z06 owners hands down do Not want to try to plug their tires... Goodyear has answered this call by changing the side wall and offer two different compounds. the run flat capability will go from 200 miles at 50 mph, to 100 miles at 50 mph... with this concession they were able to make a quiet tire that builds less heat... keeps the rubber softer and adds much more performance both wet and dry... This new EMT will handle and be as quiet as an F1 super tire, but it will be EMT... offered in both 18 and 19 sizes with wider widths for the Z06
Sorry but I have absolutely no faith in Goodyear being able to pull something like this off. My guess there will be 10 other tires out there that will improve all aspects of the C6 experience in short order.
but the coupe and vert size tire will come in two compounds... although the buyer of a new C6 doesnt have a choice... atleast not right now.. but the Mag ride suspension only will get the performance compound....
Just my .02
less than one-half of 1 % of C5 ownership even knows or cares about this Forumn. Most of the people I know that own C5s are not on the Forumn (I told them about it) . ..there is an evolution to run-flat tires in the automotive industry. Within this decades all new cars will be delivered with run flat tires. A considerable amount of the noise level comes from the lack of insulation between the C5 and the outside world.
Runflats are heavier and have stiffer sidewalls. Combine these traits with stiff antisway bars and firmer shocks and you end up with a dangerous ride around "less-than-perfect" curves. White-knuckle driving took on new meaning when the Z51 C5s came with runflats. The added bonus of non-runflats is that they are 6-7 lbs ligher (per tire) - a significant difference in unsprung weight. I never cease to be amazed at how much better riding my Goodyear GS D3s are compared to runflats and for most of us, the chance of getting a flat is very minimal. Why suffer for such a small probability - enjoy the C5 handling to its fullest!
