Summer Tire Pressure
Old Jul 26, 2004 | 08:17 AM
MrBigButt98Conv's Avatar
MrBigButt98Conv
Default Summer Tire Pressure
Hi All
Quick question, with summer temps of 90 degress & a 5 hr. highway trip planned, what would be the best crusing air pressure? I am running orginal EMT's
Thx!
Last edited by MrBigButt98Conv; Jul 26, 2004 at 08:27 AM. Reason: want to give btype of tire
Old Jul 26, 2004 | 08:25 AM
CAJUNY2KC5's Avatar
CAJUNY2KC5
If you're running GY EMTs start out at 30psi cold. They'll heat up to 35psi or so with no problems. Just be sure you don't start out with low pressure.
Have a good trip.
Old Jul 26, 2004 | 08:29 AM
MrBigButt98Conv
30 cold.. wow, I start out now at 26-27 cold. I was concerned that they may get up to 35. But I guess that OK.?
Old Jul 26, 2004 | 08:39 AM
fast2000vette's Avatar
fast2000vette
You can run up to about 42 or so (hot) before your high press alarm comes up. I like the stiffer sidewall from the higher press so I have mine at 37 lbs cold. It is all a personal choice.
Old Jul 26, 2004 | 01:39 PM
Just set your pressure to 30 psi cold. That should work year round.
Old Jul 26, 2004 | 01:51 PM
bsmith's Avatar
bsmith
St. Jude Donor '06-'07-'08-'09
just remember to adjust seasonally
Old Jul 26, 2004 | 01:55 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
You might check the sticker on your door. Running under-inflated tires wears them out and can be a source for a blow-out.
HHC5's Avatar
HHC5
All four of mine are 29 cold.
To Summer Tire Pressure
