Drilling Holes Part 2
Old Jul 26, 2004 | 11:26 AM
BigJoe's Avatar
BigJoe
Default Drilling Holes Part 2
How about some pics of how folks have drilled or cut the fog light surround when adding Z06 screens? Is there anything behind it to worry about if you just whip out the drill and have at it?
Old Jul 26, 2004 | 11:33 AM
Lancer033's Avatar
Lancer033
I cut a big square out of mine,there was a wire behind the right side one that you could hit, but if you know it's there it's to worry about. If you stick your hand up there, you can feel anything that might be in the way
Old Jul 26, 2004 | 03:23 PM
BigJoe's Avatar
BigJoe
ttt
Must be more than one that has done this... I'm planning on doing it this weekend and I don't want to screw it up.
Old Jul 26, 2004 | 04:23 PM
b98's Avatar
b98
Default holes
cut a long slot in the top , this will help direct the air upward , also cut about 1inch out of the hood weather strip at the windshild dr. side, this vents the air out.
Old Jul 26, 2004 | 04:58 PM
Rattler71's Avatar
Rattler71
Just curious, does this allow water in if you are driving in heavy rain?
What is behind the screens on the Z06 , are they drilled?
Scott
Old Jul 26, 2004 | 05:05 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
This is a very bad thing to do... the hood seal prevents engine vapors fromm entering the outside air intake area... at the cowl,, It is amazing how some people do somethings with every great intention, they think they are a hero for people adopting their Idea... but in reality, its the blind leading the blind... the rear hood seal is there to chanel engine vapors away from this intake and out throught the bottom of the engine bay...
Old Jul 26, 2004 | 06:23 PM
Autoworker's Avatar
Autoworker
Took an 1-1/8 holesaw,(the kind you use in a drill to install a deadbolt) and put one hole about an inch and a half away from the foglight. Can't even see it there . Could drill more if installing screens.
Old Jul 26, 2004 | 06:47 PM
blazeone's Avatar
blazeone
it's a stupid idea and can lead to fumes in the interior.
Old Jul 27, 2004 | 12:35 AM
Lancer033's Avatar
Lancer033
Scott
I'm sure that water can and does get in, but i've driven in the rain several time at speeds up to 130mph and haven't had any problems with a blackwing intake (yes i drive over 100mph in the rain)
nothing is behind the Z06 screens. GM just left that piece of plastic off, You could just take it off, but you would loose your factory fog lights
Old Jul 27, 2004 | 01:08 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
All good to know. I am in the process of finding the best deal on the screens.
Old Jul 27, 2004 | 01:51 AM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
don't you hate mis-information
sort of like being told to remove the screen from the intake.
Old Jul 27, 2004 | 03:25 AM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
I asked about this around a month ago and was rewarded with alot of replies and great discussion. I was also given a link to another thread which provided several more pages of great info. But due to the new forum format, I have no idea how to post the link to my original thread. If you feel like searching under my created threads, I'm sure you'll find it, which should answer all your questions and show you some pics of what people have done. Good luck.
Old Jul 27, 2004 | 09:28 PM
BigJoe's Avatar
BigJoe
Well I did it finally. Took a 1 1/4 inch wood bit (the flat shaped one) and drilled 4 holes in each side, using a slow speed electric drill. They fit with about a half inch in between. Put the screens back in and can't see a thing. I noticed a wire about 2 inches behind the passenger side surround, so, if you are really energetic with your drilling, be carefull. Nothing at all behind the driver's side. Only real problem was that some of the cut out holes fell down inside the fascia, never to be seen again (I hope).
Old Jul 27, 2004 | 11:27 PM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
It may or may not be a good idea to cut a small piece of the rear seal off at the extreme outer edge drivers side, but fumes???? Unless you have an exhaust leak I don't see what fumes could possibly enter the interior. I dont see any harm in this and have read many post about it and if I am not mistaken it is recommended by the author of the Halltech stinger fresh air install as well.
Old Jul 28, 2004 | 08:09 AM
gsmithkaty's Avatar
gsmithkaty
Sounds great, will be using your procedure this Saturday
Thanks for posting BigJoe
Old Jul 28, 2004 | 09:45 AM
IM QUIKR's Avatar
IM QUIKR
I used a 1" spade bit. Any bigger and you can see it from a mile away. It also keeps little and big fingers out of there.
Old Jul 28, 2004 | 10:10 AM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
I did the same thing, but had a lot of plastic curlings hanging. So, I cleaned up the holes with a Dremel Tool.
Old Jul 28, 2004 | 10:25 AM
BigJoe's Avatar
BigJoe
Me too. Except I cleaned them up with a sharp knife. Same effect. But, if you put the Z06 screens on afterwards, you can't see the holes anyway.
Old Jul 28, 2004 | 10:28 AM
IM QUIKR's Avatar
IM QUIKR
Yup. Me too, but just wrap your finger in sandpaper and smooth it out. This way the holes stay round. It took all of 20 minutes. Find your center line first and with a straight edge, mark it with a pencil so each hole is in line. The spade bit has the spike tip which won't wander like a drill bit will when you start the hole. And go slow so you don't damage the plastic.
To Drilling Holes Part 2
