EZ Pass
Old Jul 27, 2004 | 05:49 AM
sebringsilver97coupe's Avatar
Originally Posted by LTCHAPPA
I finally ended up attaching it to the front plate,looks ugly but I only keep it on in the summer when I cruise to the Jersey shore.
well a frt plate on a vette looks ugly anyway so why not do double ugly.
Old Jul 27, 2004 | 08:07 AM
Alex1217's Avatar
Alex1217
St. Jude Donor '08-'09
I recently got my ez pass and I refused to stick that hideous white box on my windshield, so I just keep it in my center console and when I reach a toll booth, I just hold it up against the windshield and it works perfectly. Its made caravaning with other fellow corvette guys across state lines much easier, right Sam?
Old Jul 27, 2004 | 08:46 AM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
Originally Posted by TexasRedZ06
I've had one of the front plate ones, mounted behind my MagRed plate cover, and it still didn't work. Not sure if it was the MagRed paint, or something else. The front plate thing will install under the plate cover, so it is hidden. Just didn't work for me.
Mine works fine here in Houston.stuck right beside the mirror as high as I could get it.I guess it does,been thru plenty of times and no problems so far.
Old Jul 27, 2004 | 09:00 AM
jimhallhdg's Avatar
jimhallhdg
Default 99 Coupe
I have one of the license plate mounts that when I am in the vette I prop it up on the defroster outlet inside the car and it works 95% of the time. I have the unit because of my 2000 CRV where I velcro it outside underneath the windshield wipers.
Old Jul 27, 2004 | 09:33 AM
2K Vette's Avatar
2K Vette
I was told that my EZpass would not work when I got my vette.
I have it in the glove compartment and when I go through the tolls, I place it on the windshield. I have no problems.
Old Jul 27, 2004 | 09:45 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Mine works right through the roof panel. It's hidden behind the visor
I use it every week.
Old Jul 27, 2004 | 10:31 AM
C5 Curmudgeon's Avatar
C5 Curmudgeon
I've got one of the license plate mount transponders velcroed to the top of my radiator shroud, on the driver's side. Works like a champ!
Old Jul 27, 2004 | 11:10 AM
Tenderfoot's Avatar
Tenderfoot
No problems here. If Sonny Corleone had EZPass, he still would be alive
Old Jul 27, 2004 | 02:13 PM
Jack Behrle's Avatar
Jack Behrle
Default EZ Pass
I have been using an EZPass for a year in my 99 FRC with no problems. I installed it on the top of the windsheld directly to the right of the mirror mount. Works great!
Old Jul 27, 2004 | 02:31 PM
jmb2232's Avatar
jmb2232
Now that was funny!
Old Jul 27, 2004 | 08:53 PM
RPOZ51's Avatar
RPOZ51
From: For the strength of the pack is the wolf . . . . . . and the strength of the wolf is the pack.
I use the suction cup holder, and it's mounted right in front of the mirror.
Haven't had any problems.
Old Jul 27, 2004 | 10:29 PM
EscapePod's Avatar
EscapePod
Originally Posted by gordonb50
Switched it between pickup truck and Vette until they sent me a nasty letter about switching vehicles. Not supposed to do it there. .
So what if you stopped at the coin toll window and said to the operator, "Hey, these coins are from out of my other car. Are they still good to use for this one???"
Old Jul 28, 2004 | 02:47 PM
  #33
Subw00er's Avatar
Subw00er
I can offer some suggestions as I have researched and implemented this technology at work. The ezpass transponder is an "RFID tag". Radio Frequency IDentification has been around for many years, but has only recently (last 5-10 years) gotten popular with more advanced/cheaper production methods.
Anyway, inside the tag you will basically find a small RF transponder and a battery. RF does not like to be directly next to metal, so, for example, attaching the tag to a flat metal surface would be the WORST place to put it (ie metal film on windshield). Ideally, the tag should be at least 3"+ from any metal surfaces.
I would look to see where the RF antennas are at your local tollbooths, mine are towards the left side - you should see an arm with a small antenna at the end. place the tag towards that area.
As the bodies on our cars (I have a z06) are fiberglass/plastic, this should provide only a small reduction in signal strength/path if the tag were to be mounted inside the car, either in the interior (under the roof as someone mentioned) or even under the hood. I would guess that the best place is probably towards the front of the engine compartment, under the hood, away from as much metal as possible. I believe the tags are air/water tight, so this is fine to do - place it in a ziplock if you are worried about it. When velcro'ed or tie-strapped down, make sure it is in the same orientation as it would be if it were on the windshield - this will make a difference.
Give it a try, I bet it will work great. Please post results!
Old Jul 28, 2004 | 04:09 PM
  #34
rrross's Avatar
rrross
I have e-z pass mounted on my windshield and it works fine on the GSP, NJPKE and the PA tunnels
Old Jul 28, 2004 | 04:16 PM
  #35
Adrian-S's Avatar
Adrian-S
I actually have mine installed on the back of the rear view mirror, on the passenger side of it.
From outside, you can see it slightly, from inside driver, nothing at all.
Works every time.
-adrian
Old Jul 28, 2004 | 04:56 PM
  #36
DEM74's Avatar
DEM74
I just toss mine up on the dash before going through the toll... Hit the gas on the other side and it automatically comes back to me and goes back into the arm rest......
Old Jul 28, 2004 | 07:52 PM
  #37
Black05's Avatar
Black05
Thanks for all the advise.
I'll try everything.
Something's gotta work.
Old Jul 28, 2004 | 07:58 PM
  #38
SPDaylightFan's Avatar
SPDaylightFan
I flash mine out the window ... if it is raining or I am lazy . I hold it behind the glass .. works every time .. Bolt it to the front .. glue it to the window ... these people must all drive pony cars .. ugh .
Old Jul 28, 2004 | 09:06 PM
  #39
Automag928's Avatar
Automag928
Same here (Nice car btw )
