Automatic transmission maintenance
Old Jul 26, 2004 | 07:47 PM
Easygoing's Avatar
Easygoing
Default Automatic transmission maintenance
I have a 1998 automatic which is getting close to the 50K miles range.
When is the recommended time to service the transmission? Should the fluid be changed and if so, is there a special type that is used.
I was hoping to do this myself, but maybe special equipment is needed??? Any suggestions? I want to take good care of this baby.
Thanks!
Old Jul 26, 2004 | 09:18 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
The transmission has a capacity of about 10 quarts.Removing the pan and changing the filter will only replenish about 4.5 quarts I suggest that you find a service center that has flushing equipment such as "BG" services offer to completly flush the system including the cooler and replenish with 10 quarts...30-40,000 would be the suggested interval
Old Jul 26, 2004 | 10:47 PM
IMQUIK's Avatar
IMQUIK
Put the good stuff in when ya do it!
Old Jul 27, 2004 | 12:45 AM
ValiantSailor's Avatar
ValiantSailor
GM has a pamplet which tells when you change oil and fluids. If it isnt there dont do it. I ran my GMC Jimmy for 170,000 and never changed it. Most trannies are good for the life of the car without changing it...by the way, dont take it to AMMCO or speedy lube.
Also,,check the fluid yourself before taking it if you insist on changing it,,I had a very bad experience with AMMCO once.
Good luck
Old Jul 27, 2004 | 01:41 AM
BHP's Avatar
BHP
Flush and filter.
Old Jul 27, 2004 | 07:49 AM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
What is the "good stuff"?
Old Jul 27, 2004 | 09:21 AM
IMQUIK's Avatar
IMQUIK
I can't say
Old Jul 27, 2004 | 09:55 AM
bsmith's Avatar
bsmith
St. Jude Donor '06-'07-'08-'09
depends on the driving conditions.
according to the manual it can need changed anywhere from 15000-50000 miles.
Old Jul 27, 2004 | 01:40 PM
On the automatic cars I have owned, a change at 45-50K miles has been the norm.
Old Jul 27, 2004 | 06:49 PM
Autoworker's Avatar
Autoworker
Just did mine this spring, wasn't hard at all. Bought the filter kit from Rock Auto. The filter just pops in place. Did have a little difficulty in getting the filter seal changed in the valve body . Put in 5 qts. of Dexron 3. I would suggest if you don't already have one, to buy a set of GM service manuals for your specific year. Has the whole procedure in black and white. Couldn't do without them.
To Automatic transmission maintenance
