Does Light under hood shut off by itself?
Old Jul 27, 2004 | 08:25 PM
Dave1998's Avatar
Dave1998
Default Does Light under hood shut off by itself?
I plan to do some clean on the engine this week and do i need to disconnect the light? if so how? Let me know. thanks !!!
Old Jul 27, 2004 | 08:29 PM
Scratch's Avatar
Scratch
Veteran: Marine Corps
St. Jude Donor '03-'04-'05-'09
It will shut off after about 5-10 minutes.
mrw173's Avatar
mrw173
St. Jude '03-'04-'05-'06-'07-'08-'09
Default Yes
Mine times out after about 10 mins.
Old Jul 27, 2004 | 08:31 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
It goes off after about 10-15 minutes.
If you open a door (or hatch) after it has shut off, it wil come on again for another 15 mins.
You shouldn't need to disconnect it. I have unplugged mine, only because it bugs me at car shows.
I used to show it with the light mostly on all day long (always opening the doors) and it was never a problem battery-wise.
Old Jul 27, 2004 | 09:13 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
The plug is on the passenger side right by the light. Easily unplugged.
Old Jul 27, 2004 | 09:38 PM
Dave1998's Avatar
Dave1998
Old Jul 27, 2004 | 09:46 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
Originally Posted by Dave1998
No problem. Now. How can you confirm that the light goes out in the refrigerator when you close the door????
Old Jul 27, 2004 | 09:49 PM
CAPN17's Avatar
CAPN17
By staying inside with the beer and cold cuts, how else.
Old Jul 27, 2004 | 10:06 PM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
I just yanked the bulb out of mine...at a windy car show it kept moving enuf to light up all the time.
Old Jul 27, 2004 | 10:09 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
Aha!!! Now if I could just get the cable company to run the Speed Channel in there, too.................
Old Jul 27, 2004 | 10:44 PM
It will shut off by itself after about 15 minutes. Otherwise, there is a connector down on the radiator shroud on the passenger side that can be taken apart and the light will stay off.
Old Jul 28, 2004 | 01:35 AM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
If you want to unhook the light just follow the wire down from the light itself and you will find out where to unhook it is very simple if i can do it so can you.
Old Jul 28, 2004 | 07:11 AM
HHC5's Avatar
HHC5
Mine goes off in 15 minutes
Old Jul 28, 2004 | 07:15 AM
AU N EGL's Avatar
AU N EGL
Does the refigerator light go out when you close the door?
Old Jul 28, 2004 | 07:18 AM
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
Great. I'm gonna try that this weekend, AC, food, beer, and cable!
Old Jul 28, 2004 | 07:24 AM
AFVETTE's Avatar
AFVETTE
Mine goes out after about 10 minutes, but I did notice that it will re-cycle back on if the car is disturbed. Like at a car show and you open a door, or pop the deck lid etc. So I just unplug it to be sure I keep battery drain to a minimum.
Tom
Old Jul 28, 2004 | 07:59 AM
Deluxe's Avatar
Deluxe
St. Jude Donor '06 thru '16,'22,'24
If it's the original bulb, it's a refrigerator bulb and will work correctly. If you ever need to change it be SURE to find a refrigerator bulb!
To Does Light under hood shut off by itself?
Old Jul 28, 2004 | 08:00 AM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
St. Jude Donor '05-'06-'07
...wait
...dont bump
...or unplug
...I just removed mine all together
Old Jul 28, 2004 | 08:10 AM
CAPN17's Avatar
CAPN17
Change it to an LED and live forever.
Old Jul 28, 2004 | 08:57 AM
CAJUNY2KC5's Avatar
CAJUNY2KC5
Hmmmmmmm. What mods can I get for a GE refrigerator??? Cold Air Induction? Free Flow Exhaust?
