Automatic Climate Control Problem
Old Jul 27, 2004 | 11:12 PM
Cosmo Kramer's Avatar
Cosmo Kramer
Default Automatic Climate Control Problem
About two days ago, the display on my automatic climate control started getting dimmer. Now, the display is so dim that it's barley legible. The climate control function works fine. Anybody else encounter this problem? If so, what's wrong?
Old Jul 27, 2004 | 11:16 PM
eddie44's Avatar
eddie44
St. Jude Donor '03
Start watching the parts for sale or ebay. It's a goner. I haven't had the problem but read that once the readout goes you just have to replace it. Can't explain why but the do go out occassionally. Not cheap from the dealer, so I would shop used. I've had mine out to install XM radio and it's not tough.
Good Luck!
Old Jul 28, 2004 | 12:36 AM
radwebster's Avatar
radwebster
when i had my 98, it was the same thing. i didn't even notice it was dim until one day it was 100 degrees out, and that "1" lit up so freakin bright...
Old Jul 28, 2004 | 06:10 AM
Others have reported this problem too. About the only fix I have heard about is to get a new unit. Check with Gene at the KarShop in Florida for prices on a good used one.
Old Jul 28, 2004 | 08:27 AM
Cajun99's Avatar
Cajun99
What they said...start shopping for another
Old Jul 28, 2004 | 09:06 AM
Cosmo Kramer
How do I reach Gene? Thanks.
Old Jul 28, 2004 | 10:35 PM
Cosmo Kramer
JDs00PewterCoupe.....Thanks for the tip to contact Gene. Gen has a used unit from a '03 he'll sell me. A couple of questions, however:
1) Will a unit from a '03 work/fit in a '98?
2) Did GM improve the programming from '03 to '98 (the programming in the '98 stinks?)
3) What is the GM part number for the unit?
4) Is it an easy job to switch out the units (unplug one unit, plug in the other unit?)
Thanks.
Old Aug 7, 2004 | 10:31 PM
Cosmo Kramer
Got the new/used unit from Gene at Karshop today. Install was a piece of cake, less than 1/2 hour. Of course, after installing the gauge bezels (thanks, Johnno,) I had previous experience.
GM should be sued for price gouging. $1K for a new unit and 2.5 hours for a GM tech to install it is outrageous
To Automatic Climate Control Problem
