[Z06] Stiff Breathless shifter fix?
Old Jul 28, 2004 | 12:42 PM
Editor's Avatar
Editor
Default Stiff Breathless shifter fix?
Anybody else out there have a Breathless Performance Products shifter that's super stiff? I just installed one that I picked up at Bloomington Gold and I love the short, precise throws, but even with the softest (black) springs in it, it's really hard to get up into first and reverse. I've read of similar problems with Hursts and B&M shifters. Is that just the nature of a high-performance shifter? Or will it loosen up over time? I don't want to wimp out and go to mushy springs, although BPP said they'd get some from their spring supplier if I wanted.
2002 Black Z06, lowered, BPP shifter.
Old Jul 28, 2004 | 12:45 PM
CAPN17's Avatar
CAPN17
Time loosens all things, shifters and bodies.
Old Jul 28, 2004 | 02:16 PM
cactusZ06's Avatar
cactusZ06
I have the BPP shifter. Everyone who gets in my car wonders how on earth I manage to shift. It's stiff, even with the softest springs. Stick with it, and you will grow to love it.
Old Jul 28, 2004 | 05:57 PM
ALLKAR's Avatar
ALLKAR
Senior Member
Cruise-In V Veteran
I've had mine almost a year. It loosens up!
Old Jul 29, 2004 | 12:26 AM
VETTEC5's Avatar
VETTEC5
I took mine appart after 4 months and messed around with a pair of pliers and the springs. Then I greased the interior body real well and now my wife can drive it!!!!!!!!!!!
I also did put a delrin shift ****, much better to hold and control.
Hope this helps.
Tony
Old Jul 29, 2004 | 12:59 AM
Bill Dearborn's Avatar
Bill Dearborn
I went to the soft springs and find them too hard also. One thing that may be causing the problem is the stock rubber boot that is supposed to fit around the shifter base. When I reversed mine it would not fit over the BPP base and the stiff portion of the boot that fits around the stock shifter interferes with the movement of the shifter. I have been thinking of removing the springs altogether but I hate the rattle coming from the shifter everytime I am on hard on the throttle so I may just go back to the stock shifter which seems to be a better mechanism all the way around.
By the way it is just as hard to move back and forth as it was when I put it in last year. They do not loosen up. I missed 1st gear three times today because of the amount of force it takes to move the lever to the left.
Bill
Old Jul 29, 2004 | 03:10 PM
Editor's Avatar
Editor
Default stiff breathless
Thanks for the replies, guys. But what scares me now is the thread by somebody who just had $3000 worth of warranty work done, because just today my shifter started acting up - I can't get it into 1st or 3rd without forcing it, and it won't go into 5th, 6th or reverse at all - something must have come loose in there and is jamming the shifter. Can't hardly wait to get home and take it apart and see what fell/broke off.
Old Jul 29, 2004 | 05:15 PM
TheDVS1's Avatar
TheDVS1
Make sure the shifter boot (as someone mentioned) isn't binding up the shift lever. I think the idea of reversing the boot is silly. I plan to trim my boot to the proper size so that it fits over the shifter base. This was suggested in another thread and make by far the most sense to me.
Good luck on finding the culprit! Let us know what happens.
Old Jul 29, 2004 | 08:13 PM
ALLR RED's Avatar
ALLR RED
I changed mine and went with the softer springs and it will loosen up a bit. I luv mine, one of the best mods you can do.
Old Jul 30, 2004 | 01:04 PM
Editor's Avatar
Editor
This morning I changed to the white springs, which are actually supposed to be stiffer than the black ones, but feel just a tad softer. Also, the problem I had with it suddenly not shifting into several gears? Turned out to be a nut and washer from the handle that had fallen off - as I hoped and suspected.
One word to solve that and most other problems: Locktite!
To Stiff Breathless shifter fix?
