CLB install throwing codes. HELP!
Old Jul 28, 2004 | 04:06 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
Default CLB install throwing codes. HELP!
I have an '04 MN6 C5 and thought that I'd get ahead of the potential problem. The adapter didn't work so I just used the key to disengage the lock. When I reassembled things I got the code. Any help?
Old Jul 28, 2004 | 04:24 PM
Patches's Avatar
Patches
The reason the adapter is used is to "fool" the computer into thinking the lock is still engaged when, in fact, it isn't. It "sneaks" the lock open when the PCM is in passive monitoring with the key out of the ignition. That's when the bypass is slipped into the circuit, restoring the locked signal even though the column is no longer locked. By using the key, you've allowed the computer to see through the bypass's false locked signal when the ignition is off, thereby setting the code when you start the car.
Try resetting the DIC to see if the code goes away. If not, I'd uninstall the bypass and try it again. If your adapter isn't working, contact the vendor and have them send a replacement.
Old Jul 28, 2004 | 04:31 PM
WWK888's Avatar
WWK888
Check and make sure your cigarette lighter is working properly (no blown fuses), that may be why the adapter didnt work.
Old Jul 28, 2004 | 04:36 PM
Corvette SSX's Avatar
Corvette SSX
St. Jude Donor '08
Also, make sure the fuse in the ligher plug that came with the bypass is good. I've seen them go bad between shipping and receiving of the bypass kit.
Old Jul 28, 2004 | 04:42 PM
xilr8n's Avatar
xilr8n
Patches probably has it all solved for you.
It will work, I just did my '04.
The key is to just follow the directions
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
try the other plug in the armrest too..
Old Jul 28, 2004 | 04:44 PM
madeouttaglass
Senior Member
Cruise-In V Veteran
Jon wrote back already too. Great service! I pulled fuse # 25 and will check the unlocker as I wait 20 minutes for the BCM to forget what I did. I'll post again in a little while. Thanks everyone!
Old Jul 28, 2004 | 04:45 PM
madeouttaglass
Senior Member
Cruise-In V Veteran
Nobody ever told me that!
Old Jul 28, 2004 | 04:52 PM
bsmith's Avatar
bsmith
St. Jude Donor '06-'07-'08-'09
I had to go get a 1A fuse just last night because that little hair thin wire was toasted...
Old Jul 28, 2004 | 05:11 PM
madeouttaglass
Senior Member
Cruise-In V Veteran
And once again I prove to the forum that I am an idiot. Turns out that the tiny fuse in the unlocker was toasted. I pulled fuse #25 and retried it the way the instructions said to. Viola! It works! Or should I say the CL doesn't? Thanks to everyone who helped and especially to Bob Williams who gave this to me for nothing when he had his lock removed on his A4.
Old Jul 28, 2004 | 05:16 PM
Patches's Avatar
Patches
Good work!
Old Jul 28, 2004 | 05:24 PM
Gonzo's Avatar
Gonzo
Originally Posted by Patches
Good work!
Good Advice Patches
Old Jul 28, 2004 | 05:50 PM
I just installed mine. No codes so far, so I hope I did it right. Good luck getting yours reset.
Old Jul 28, 2004 | 06:09 PM
Mark 84ltblu's Avatar
Mark 84ltblu
SE Ohio Event Coordinator
CI-V Car Show Winner
Cruise-In II Veteran
Cruise-In III Veteran
Curise-In V Veteran
Cruise-In VI Veteran
Jon is one of the most stand up guys you'll ever deal with as a vendor.
Old Jul 28, 2004 | 06:16 PM
madeouttaglass
Senior Member
Cruise-In V Veteran
Now that the dash is apart, it is time to do the Patches exhaust cut out mod.
Old Jul 28, 2004 | 06:36 PM
Patches's Avatar
Patches
That's quite a leap! But, by all means - go for it!
Old Jul 29, 2004 | 10:44 AM
Gonzo's Avatar
Gonzo
I just saw that on another thread, with Video. Now that is a thing of beauty
You did a heck of a great job on that, I wish I had seen it before I went with an aftermarket exhuast
To CLB install throwing codes. HELP!
