[Z06] best launch method
Here is a link to one on the threads that Robz referred you to:
Z06 Launch Techniques
Couple thousand words on what I've learned in 250+ passes in two Z06s. Once you've read through that, if you have specific questions, drop me a PM.
Wringing the best times from a seriously traction-limited, manual-tranny car, such as the Z06, requires seat-time, even for a super driver. There are a lot of things to get right...
(1) the launch rpm
(2) the clutch release
(3) three shifts
(4) the throttle postion and hook on shifts
(5) the shift points...on and on.
So it takes seat time and passes to embed the techniques in muscle memory and learn to read what the track surface and conditions dictate on any particular day.
If a driver (1) has good leg speed and reflexes, (2) is very attentive to proper techniques and what works (incl record keeping) and (3) runs on tracks that have average-good management and surface prep, then it should take 50-75 passes to become reasonably consistent with the car. (all runs but one on a day are within one or two tenths).
Good luck with your car.
Ranger
If you are seeking max acceleration and good ETs, then you need to launch in first gear.
It takes some practice to start getting 2.0X 60 foot times. Even more practice and better technique are needed to drop the 60' under 2.00.
Study, patience and practice....
Ranger
rev to 3000rpm
Let out the clutch part way slipping it a little
but still there will be some wheel spin or wheel "slipping" is even better
Feather the throttle as you surge forward to about 60"
Go WOT from now on
I do a short first gear burnout and hit the rev limiter.
I launch aroud 2500 rpm with stock tires.
It took about ten launches, but I can consistently get 1.90 short times, but I am only running 12.3 at 115 mph. My goal is 11s on street tires when I get my cam and heads done this winter.
Mike
Hell NO! Let me tell you from prior experience, you cannot take off at 3500 RPM, from 2nd gear. I thought that it would be easy.............dropped the clutch at 3500 RPM and......the whole cabin filled up with clutch dust and the clutch was FRIED. Once cool, it worked kinda' ok but.....going up into my driveway, you could smell the clutch. I traded it for my 2004 Z06................within a week. Learned a huge lesson on that one!
