HeadLight Problem at Night
Old Jul 29, 2004 | 08:27 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Default HeadLight Problem at Night
Last night I got in my car it was around dusk time and started the car. The inside lights came on, but the headlights did not pop up (they are on automatic). It was somewhat dark so I turned on the switch, but still the lights did not pop up. I then stopped the car, turned it all off, and restarted and the headlights popped up.
I have a 01 6MN so the lights do not come on until I release the emergency break. I was thinking that had something to do with it, but was wondering if anyone else experienced this problem.
Old Jul 29, 2004 | 08:35 AM
robl45's Avatar
robl45
Lights probably came on but just did not pop up. I 've had that happen, turned off car, restarted, problem solved, very infrequent. As for the emergency brake, I think that is only an issue when you have it setup to automatically turn on the headlights when it is dark out and you start the car. Note that these are not auto headlights, its just a one shot deal from what I can tell, start car in dark, release break, headlights pop, they will not go off when it gets light out, nor will they turn on when it gets dark if the car was not started in the dark, pretty stupid if you ask me. My grandmothers car has automatic headlights and it is an 87.
Old Jul 29, 2004 | 08:47 AM
Wicked Weasel
That was my thought too, but nice to see others have experienced it too. Wonder why it happens...
Old Jul 29, 2004 | 09:12 AM
wit2pz's Avatar
wit2pz
My lights come on when it's dark or I drive into a very dim-lit garage. They automatically go off when the light level is bright enough. They will not go off manually, as long as the automatic "twilight on" is set. I've never had the problem of them not coming on if I turned them on manually though... yet...
Old Jul 29, 2004 | 09:56 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
All good to know!!
Old Jul 29, 2004 | 10:58 AM
robl45's Avatar
robl45
hmm, can anyone else confirm this? My lights do not work like that, they only come on with the twilight sentinal if its dark out when I start the car, they do not go on and off depending on the light conditions after the car is started. I'd think it was a bad sensor but it knows when I start the car that it is dark or light out.
Old Jul 29, 2004 | 11:49 AM
Wicked Weasel
If I remember correctly my lights will come on when I am driving and it is dark and will shut off when the sun comes up. I can verify this tomorrow morning when I leave to work. The garage should be dark enough to set the lights to on and if the rain holds out it should be bright enough outside to turn them off.
I will let you know...
Old Jul 29, 2004 | 11:57 AM
wit2pz's Avatar
wit2pz
I just checked the manual. On my 2001, and I would assume on other years with the same options, you can adjust the delay time for the lights to pop up and go down. Go into OPTIONS, select TWILIGHT SENTINEL ON, press OPTIONS again, and you get the screen where you can adjust the delay time. Press the FUEL button to increase the delay time, and the GAGES button to decrease it. Each bar is in 12 second increments. If it's set to no delay time, like mine is, you'll see your lights go up in the dark, and down in the light. Mind you, it won't be erratic, you have to be in the dark, like a parking garage, for about 10 to 15 seconds before they'll come on, and out in the light for about 15 to 20 seconds for them to go off. Hope this helps.
Old Jul 29, 2004 | 07:43 PM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Let me tell you when i went out to visit my son after i had the car for a few months it was dark out when i left his house i got into the car started it up and no lights i thought ok this can"t be right so i put them on by the switch.Go home and looked up why the headlights did not go on in my manual.Who was the nut who came up with the idea that you put the brake down and the lights go up and on.
Old Jul 29, 2004 | 09:15 PM
sebringsilver97coupe's Avatar
probally the same nut that made them happen that way on almost any of the auto headlamp cars from chevy, etc. also the DRLs are supposed to not be on with teh brake up...that way u can idle your car w/o your lights on. if i had the auto on lamps, i think id turn them off, they seem to be more of a pain than anything...
Old Jul 29, 2004 | 11:32 PM
charlene's Avatar
charlene
i had older corvettes and the lights did not go on when you put the emergency brake down.Yes i read in the manual they made them that way so you can idle with them off.
Old Jul 30, 2004 | 12:18 AM
Never had this problem. My car has the twilight feature too and they automatically come on when the light level is low enough and goes off when it gets bright enough outside. They will only work when the e-brake is released.
Old Jul 30, 2004 | 08:43 AM
Wicked Weasel
Drove the car out of the garage this morning and the lights were on. About 1 min. later down the road they turned off. Seem to work for me...
Old Jul 30, 2004 | 12:38 PM
robl45's Avatar
robl45
Mine are not working like that, anyone have any idea how to test them? Where is the sensor? I'm assuming I can cover it up to simulate darkness. The sensor seems to work because they pop up in the dark but then when it is light they do not budge, something seems screwy. Need to diagnose.
Old Jul 31, 2004 | 11:36 PM
robl45's Avatar
robl45
Ttt
To HeadLight Problem at Night
