Emergency
Old Jul 29, 2004 | 07:50 PM
Spiral Grey's Avatar
Spiral Grey
Default Emergency
Emergency brakes...
I was told by the dealership when I bought my 99, that they were supposed to be "self adjusting" . Ended up paying to have them adjusted pretty early on, i.e. around 25K miles.
My 04 has 10K miles and I am noticing that I have to pull up pretty hard to really set the emergency brake for the car not to "roll" .
Whats the deal? Do they adjust them selves? Can I "self adjust" them etc.
Please advise.
Thanks,
SG
Old Jul 29, 2004 | 08:36 PM
BWP 5P's Avatar
BWP 5P
Veteran: Marine Corps
St. Jude Contributor
I believe in the manual it says something about adjusting when you yank on it backing up. Read up on it....I'd do it but I'd have to go 10' and open my glove box
Old Jul 29, 2004 | 08:38 PM
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
It will only adjust within a limited range. By 'pull up pretty hard', do you mean, you have to pull it all the way up? or just a few clicks, and it gets stiff? If it's the latter, it's a good thing.
If you have to pull all the way up, you'll have to adjust the star wheels in the rear e-brake drums.
Old Jul 29, 2004 | 08:39 PM
I-SPEEED's Avatar
I-SPEEED
St. Jude Donor '19
I had the dealership check on my e-brake on my 99 FRC also. They found nothing wrong! The car will roll with the e-brake on and I have got used to it.
Old Jul 29, 2004 | 08:46 PM
vetterlatethannever's Avatar
vetterlatethannever
Seems the norm, I have to yank mine all the way up and it just seems to catch, once there it is tight though. Still put it in reverse as the owners manual suggests, never too safe!!
Old Jul 29, 2004 | 08:53 PM
eddie44's Avatar
eddie44
St. Jude Donor '03
Emergency brake.... what's that??? I guess that's 1 advantage to owning an A4. I just put it in P. I know the EBrake won't hold diddly!
Old Jul 29, 2004 | 09:30 PM
Rob'sC5's Avatar
Rob'sC5
Cruise-In V Veteran
St. Jude's Donor '05
Old Jul 29, 2004 | 09:33 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
holds the strap of the digital camera..
Old Jul 29, 2004 | 09:35 PM
CE2004's Avatar
CE2004
Normally, a parking brake is "use it or lose it." As you use it when you park, it continually adjusts itself. If you don't use it, components can freeze up, and you have lost the brake, and its ability to adjust until a technician lubes up the components again for you.
Old Jul 29, 2004 | 09:48 PM
Avanti's Avatar
Avanti
Of all the great engineering in the car, this ain't some of it.
Mine feels different everytime I apply it and to get it to hold I usually have to pull it to the last click I can manage. Then it holds fine; but, it never seems to be in the same place twice in a row. Great right arm exercise, though, for us left-handed people.
Anyway, I don't think it would pass for more than a "parking" brake, at most.
All the best.
Old Jul 29, 2004 | 09:59 PM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
I use mine to hold the strap of my camera bag and it works just fine. I put the bag on the passenger side floor, put the strap over the parking brake handle and it keeps the camera bag from rolling around while doing spirited driving.
Sounds like mine gets more use than most others.
Old Jul 29, 2004 | 10:09 PM
Doughan's Avatar
Doughan
Elite Member
Cruise-In III Veteran
I wonder if this issue has been addressed on the C6....Mine will barely hold on a very slight incline when pulled all the way up. Lousy at best.
Old Jul 29, 2004 | 10:18 PM
SamsBud
Guest
Posts: n/a
Mine works fine - '02 coupe.
Old Jul 29, 2004 | 10:20 PM
GrayC5's Avatar
GrayC5
From the C5 Tech Tips section of the Forum: Parking Brake Adjustment
NOTE: Evil-Twin, the author of this tip, I believe is a retired GM automotive engineer who did some work on the C5.
Old Jul 30, 2004 | 12:40 AM
The e-brake on these cars just does not want to adjust itself. I have had the dealer adjust mine about three times, all under warranty thankfully.
Old Jul 30, 2004 | 01:58 AM
BHP's Avatar
BHP
It has NO auto adjuster. You have to pull the rear rotors and turn the star wheel manually.
Old Jul 30, 2004 | 08:27 AM
CAJUNY2KC5's Avatar
CAJUNY2KC5
It's "self" adjusting only as long as you do it by your "self".
To Emergency
Old Jul 30, 2004 | 09:55 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Do the adjustment yourself. Not that hard just like the old drum brakes. It took me an hour or a little less to get it done and it now works like it should. It wasn't adjusted at all when I got in there it was at the minimum adjustment.
Old Jul 30, 2004 | 10:07 AM
manike's Avatar
manike
All the best.
Mine is like this too, and to be honest I think it's crap.
I took mine in at 3,000 miles and told them to adjust it. They said it was 'as the factory intended' and they couldn't do anything . hey did some 'standard test' and it passed. I'm still not happy with it.
I told them next time it tried to roll back down a hill (scared the hell out of me) that I'd expect to get the damage fixed under warranty.
I have to pull mine up to the very last notch on any kind of an incline to make it hold.
Old Oct 6, 2004 | 10:49 AM
BADBOYINDC's Avatar
BADBOYINDC
Default EMERGENCY brake
Well my girlfriend crashed my 02 c5 when she got out the car pull the
brake and shut the door the car rooled under a car i was so mad
i could have kicked her azz but is was chevy that did it to me they said nothing was wrong.
So i had to take the wheel off and ajust the brake my dayum self
