Question: Hood liner
Old Jul 31, 2004 | 07:10 PM
Steveo1c5's Avatar
Steveo1c5
Default Question: Hood liner
Does anyone have any pic's of their stock hood with the hood liner removed? Does it look nice without it, and does it really serve a purpose. My engine bay is all dressed up and I need to do something with the liner I know I could have it painter, but I plan on getting the MCM hood in the near future and don't want to spend the money on painting the liner.
Thanks Steve
Old Jul 31, 2004 | 07:20 PM
TRAYC7's Avatar
TRAYC7
NCM Ambassador
CI-3-4, 9 & 10 Car Show Winner
CI-3-4-5-6-7-8-9-10 Veteran
St. Jude Donor '04-'05-'06-'07-'08-'09-'10,'14, '16
St Jude Fedex Bowl Donor '09
Ive seen many aftermarket hoods without the liner and it was painted all the way through.... looked nice....
Old Jul 31, 2004 | 07:40 PM
Shylor's Avatar
Shylor
All cars use hood liners, so yes they have a purpose. Mostly used for sound dampening.
Old Jul 31, 2004 | 10:05 PM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Yes it is painted underneath the liner i have an 03 but if you take it off you are going to have holes where the liner was attached.older cars never had hoodliners like the ones they have today.
Old Jul 31, 2004 | 10:09 PM
WellAdjusted's Avatar
WellAdjusted
From: His name is Tandy Dillen. Altruism is the last Frontier.
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
St. Jude '03-'04-'05-'06-'07
Do a Search on the Forum for PaulaH.
Old Aug 1, 2004 | 01:09 AM
Shylor's Avatar
Shylor
Depends on how far back you go but most cars did have them.
Old Aug 1, 2004 | 07:29 AM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
take out the 15 or so clips that hold the thing in and judge for yourself.They pull right out..
Old Aug 1, 2004 | 08:02 AM
ooh yeah's Avatar
ooh yeah
I would also worry about heat damage to the paint on long rides.
Old Aug 1, 2004 | 09:09 AM
charlene's Avatar
charlene
the liners were not as nice back then as they are now.Some of the cars hoods looked like house insulation on the inside.I don't know how old you are but i go back to the cars starting in the 40's
Old Aug 1, 2004 | 09:15 AM
Rattler71's Avatar
Rattler71
I think car engines run a lot hotter today than they used to. Plus the engine compartment is much tighter. I would worry about heat damage to the underside of the hood if it was removed.
Scott
Old Aug 1, 2004 | 09:32 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Scott
The underhood heat isn't as high as you people like to think.
For one, look at how many people have painted their rail covers and hoodliners. It's standard automotive paint, and it holds up just fine on them, and the rail covers sit just inches above the headers/exhaust manifolds, which are the main source of heat in the engine compartment.
If you're still in doubt, go take your car out, run it hard, get it good and hot. Shut it off, quickly pop the hood, and (other than the exhaust), find a place on the engine where you CAN'T comfortably hold your hand. You won't find one. The thermostat housing and alternator housing will likely be the next warmest areas, but you can still touch them without getting burned. And that is surface temp...the air just a few inches away won't even be half that temp.
As I understand it, the primary function of the hood insulation is fire suppression. In the event of an underhood fire, it is designed to drop down and smother the fire. Sound deadening is another reason.
Old Aug 1, 2004 | 09:59 AM
jrose7004's Avatar
jrose7004
Old Aug 1, 2004 | 10:02 AM
PaC5_CHICK's Avatar
PaC5_CHICK
Default I done my own
Hoodliner 101 here is the link to the site I found when I started doing mine.
heres a picture of mine if it works
Old Aug 1, 2004 | 10:26 AM
Rattler71's Avatar
Rattler71
Scott
Old Aug 1, 2004 | 04:48 PM
The stock hood is painted under the liner. Looks good IMO.
To Question: Hood liner
