HP vs RWHP question.
Old Aug 1, 2004 | 06:33 PM
DrValidus's Avatar
DrValidus
Default HP vs RWHP question.
HP and RWHP. What is the difference? Would someone be kind enough to explain?
Old Aug 1, 2004 | 06:38 PM
NSTG8R's Avatar
NSTG8R
hp is horsepower, rwhp is rear wheel horse power ... some people measure hp at the flywheel, which gives a false sense of how much power the car has ... like my 350 hp (@ the fly) is like 315 RWHP
Old Aug 1, 2004 | 06:39 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Factory hp ratings is FWHP (flywheel horsepower). This is the amount of power the engine itself produces.
In a car, the engine output is then routed through the clutch (or TC), driveshaft (torque tube), the transmission gears, and the rearend gears, and axles...all of which consume some power due to friction. How much loss depends on a lot of things, but 15-20% loss is the norm.
RWHP (rear wheel horsepower) is the actual power put down at the wheels after all the parasitic friction losses of the drivetrain. This is what a common chassis dyno measures, which is why you see rwhp numbers used much more commonly here than fwhp.
To HP vs RWHP question.
