I'm attempting to hard wire my V1 into the accessory power plug on a 2004 Coupe.
I've followed the instructions from the Tech Tips section as well as here ... but i'll be damned if I can find this plug as mentioned in the instructions.
A couple of posts mentioned that it doesn't exist on the 2004 as it does on the previous years' models ... ?
Sorry, GM saved a nickel by eliminating the wires.
Yup - no accessory wires in the '04. I went to Aotozone and picked up a micro fuse Add-an-Accessory fuse adapter kit. Basically a wiring kit that plugs into the fuse box and gives you the accessory wires you need. I believe I used fuse slot #22 in the footwell. Plugged in, hooked up the wires, and doing fine.
What would cause there not to be any power tofuse #22?
