I just noticed after running the A/C for a while water drips onto the passenger floor mat. I felt around unfer the dash and noticed the foam under the dash was soaked. Is there supposed to be a drain outside of the vehicle, or is this normal ?
Check your drain. I just had this happen to me. It is a total pain in the butt. Shorted out the blower motor, the BCM, all kinds of stuff. Car went crazy. After the money I just spent my new wheels are going to have to wait.
Is it easier to get to the drain from up top or under the car ? Should I take the hose off clean it and re install it or take it off and leave it off ? I also heard something about just cutting the end off ? My stingers are getting installed in an hour, so I will get under it and take a look.
Thanks again for all the help with the newbie questions.
I couldnt reach my drain from the top because of a wiring harness in the way. So I go from the bottom. I think if you got the drain flap off it could be a tough one to get back on. I just pinched the end of it and the water from above rinsed it clean, not sure what was plugging it but I think I will keep an eye on it regularly.
