[Z06] heat problems
Old Aug 3, 2004 | 06:42 PM
blown01's Avatar
blown01
Cruising
Default heat problems
does anyone notice their car has less power when its hot out side?
Old Aug 3, 2004 | 08:00 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
Absolutely true! Don't expect your new best in the summer!!
Old Aug 3, 2004 | 08:24 PM
cactusZ06's Avatar
cactusZ06
hmmm...your username suggests you have, or did have, a forced-induction car. if that's the case, surely you have a basic understanding of air in an engine?
Old Aug 3, 2004 | 08:55 PM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
temp affects hp...a cool fall day & your car will feel like you just dropped a load on some new mods.
Old Aug 3, 2004 | 09:05 PM
chiefDave's Avatar
chiefDave
St. Jude Donor '05-'06
I can't wait to see what my car will do OCt here in NC. Hey Dr Ron I saw your stock 11 run post Wow! It is a bit sad as I dont think I drive that bad but my ETs and speed do not show it.
Dave
Old Aug 3, 2004 | 09:12 PM
blown01's Avatar
blown01
Cruising
hi temps affect hp ,but would it affect it by 40 rwhp?
Old Aug 4, 2004 | 09:52 AM
bobby777's Avatar
bobby777
High heat= less power! Running on 7 plugs=less power.
Old Aug 4, 2004 | 10:24 AM
lager99's Avatar
lager99
St. Jude Donor '06
Where did 40 come from? Corrected hp it would easily affect 10-15hp. What you actually feel can be way more depending on the barometric pressure...it is similar to gaining altitude. Then you could have a 40hp difference.
Old Aug 4, 2004 | 10:50 AM
Michrider's Avatar
Michrider
Yup, I have found my Z06 to be very affected by climate, especially heaat and humidity. I wouldn't doubt it to be 40 or more horse difference. It is very noticeable seat of the pants. Absolutely screams when cool and dry fighting for traction and hitting the rev limiter real quick in the low gears. My first couple of drives on hot humid days I thought there was a problem, it felt that piggish and couldn't spin the tires. That much seat of the pants difference has got to be more than 10hp loss.
To heat problems
