Engine warning light
Old Aug 10, 2004 | 11:11 AM
dmaccor's Avatar
dmaccor
Default Engine warning light
Does anyone know how to cancel the engine warning light on the instrument cluster?
I have changed the oil/filter!! Everything is running normally?
What else should be checked?
Old Aug 10, 2004 | 11:15 AM
Mixxit's Avatar
Mixxit
Check for codes on the DIC (there are many threads on how to do this if you don't know how). If there is a "current" code, it may be causing the service engine light to come on. You'll need to clear the code. You'll also need to investigate the code and see what's causing it. Hope this helps!!
Old Aug 10, 2004 | 11:19 AM
dmaccor's Avatar
dmaccor
Thanks for the quick reply. I am in Guam and the car is in Houston....will check asap
Dave
Old Aug 10, 2004 | 11:45 AM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
To Check codes:
With the key turned to just before starting the engine,
While holding the OPTIONS button in, tap the FUEL button 4 times and the codes will start to scroll off.
Once finished scrolling through them all, you will enter manual diagnostics mode and you can cancel codes one at a time, BUT you may want to take note as to what codes are there.
Something has made your engine light come on.
Good possibility you'll see the PCM code of 0410, seems to be a very common code on these cars.
Old Aug 10, 2004 | 06:50 PM
dmaccor's Avatar
dmaccor
Thanks Glenn....Is that procedure in the Z manual? Really appreciate your heads up!!!
Dave
Old Aug 11, 2004 | 03:48 PM
dmaccor's Avatar
dmaccor
Is the pcm 0410 a "fault code" or something important?
Old Aug 11, 2004 | 04:47 PM
LH04's Avatar
LH04
Check your gas cap... is it to lose? If that's the problem then after a few runs it should clear itself (This just happened to me).
Old Aug 12, 2004 | 06:27 PM
dmaccor's Avatar
dmaccor
Good possibility you'll see the PCM code of 0410, seems to be a very common code on these cars.[/QUOTE]
What does the 0410 code mean?
To Engine warning light
