Cruise Control Problem
Old Aug 16, 2004 | 01:28 PM
kluczenk's Avatar
kluczenk
Default Cruise Control Problem
I went out on a long drive through Wisconsin on Sunday and on the return trip I decided to just hit the cruise control and kick back for a bit. To my suprise when I flipped the switch to ON and then tried to SET the speed nothing happened. There was no info on the DIC being displayed and the process obviously did not work. Does anyone have any ideas? Is there a place I can check for codes (if they exist for cruise control)? My warranty just let up last month so unfortunately I can't bring it in for free checkup/repair. Any input/experience would be greatly appreciated!
Thanks!
By the way, you'll all be happy to hear I passed about 10 vettes throughout the day that I know saw me and EVERY ONE gave a big wave.....3 generations worth too!
Old Aug 16, 2004 | 01:48 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
The GM list of why the cruise control on a Corvette won't engage is two pages long. Any number of conditions won't allow it to engage.
The most common (to me) is that you are still accelerating when you try engage it. Your speed has to be fairly constant for it to set. Another is that if your active handle is active it won't engage.
And of course, you can't engage the cruise control at speeds in excess of 165 mph.
I'd suggest that you try it again to see if it works now before taking it in to the shop.
Old Aug 16, 2004 | 02:48 PM
VetteSiNz's Avatar
VetteSiNz
Now I wonder why I can't set my cruise control.
Old Aug 16, 2004 | 03:25 PM
Formula52's Avatar
Formula52
Do a search on cruise control, there is an easy fix for it you can do yourself. It involves pushing on 2 moduals located behind the brake pedal. Happens to me every once in a while.
Hope this helps,
Steve
Old Aug 16, 2004 | 03:36 PM
kluczenk's Avatar
kluczenk
Hope this helps,
Steve
Thanks all, this forum is great! I tried the search but maybe I need to dig deeper in time to find an applicable post.
Old Aug 16, 2004 | 03:49 PM
Formula52's Avatar
Formula52
Try under C5 Tech section
Old Aug 16, 2004 | 03:52 PM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
It happens in my truck once in a blue moon. After I shut it off & restart, it works.
Old Aug 16, 2004 | 05:32 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
Obviously it's a design flaw.
Old Aug 16, 2004 | 05:36 PM
If your car is only a month out of warranty, you may be able to get the dealer to fix it. My dealer has done this for me as a means to keep my business. Worth a try.
Otherwise, it could be a number of factors, including a loose wire, bad cruise unit, etc.
Old Aug 16, 2004 | 10:29 PM
Admiral Fairway's Avatar
Admiral Fairway
Try putting your foot under the brake pedal and lifting up, if you can then set you cruise you need to adjust your brake switch.
Old Aug 18, 2004 | 12:00 AM
kluczenk's Avatar
kluczenk
Default Don't all laugh at once
Well, I took the car out after reading some of the posts last night as the problem was really bothering me. Well, when I got out on the road I took a look at the turn signal/CC handle and it finally struck me that I had been pressing the wrong button!!! I was simply flipping the CC switch to ON and then trying to set the cruise control by pushing that same switch one click forward which is the accelereate function. I then pushed on the correct button (the one at the end of the handle, on the crown) and the cruise control engaged successfully!!!! In my defense, I have been spending much more constant speed driving behind the wheel of my beater 2nd car (1990 Plymouth Voyager) which uses the behavior I originally performed to set the cruise. Oh well and thanks for all the input.
Old Aug 18, 2004 | 12:13 AM
GrayC5's Avatar
GrayC5
My dealer replaced an A/C compressor at no charge on my Chevy truck that was 2 months out of warranty. Never hurts to check.
To Cruise Control Problem
