Fuel Rail Removal?
Aug 18, 2004 | 01:01 AM
Fuel Rail Removal?
OK, flame me as an idiot, but at first glance, I can't seem to figure out how to remove the fuel rails in my '01 cpe. I've looked for bolts, but can't seem to see any. Granted, I lifted the hood for a quick check in my garage after dark, and maybe the lights don't happen to shine quite perfectly, but I would think it would be obvious.
I'm preparing for a decarb with SeaFoam, so I need to see where the vaccums into the intake are.
Sorry for the stupid question.
Aug 18, 2004 | 01:12 AM
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
this is one of the hardest things you will do under the engine!!!
They just pop off, just lift up
Aug 18, 2004 | 01:14 AM
Aug 18, 2004 | 01:16 AM
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Oldtimer
Remove the Plastic Fuel Rail Covers by gently prying them up. They should easily pop out.
Aug 18, 2004 | 01:17 AM
The fuel rail or the fuel rail "covers"?
Aug 18, 2004 | 01:21 AM
St. Jude Donor '11
Aug 18, 2004 | 01:35 AM
Quote:
Oops, my bad! Yes, I meant the covers.
BTW, I noticed you're in Sac. I'm in EDH. Nice to meet you. :-)
Aug 18, 2004 | 01:37 AM
You're kidding! I guess that means everything on this car is easy to remove an install, huh?
Aug 18, 2004 | 01:46 AM
St. Jude Donor '11
Quote:
fuel rail covers are the only thing that is easy...
Aug 18, 2004 | 01:49 AM
Quote:
The tire treads are really easy to remove also
Aug 18, 2004 | 06:33 AM
Just lift up. Hardest part is getting the driver's side one past the fuel line without scratching the cover.
Aug 18, 2004 | 11:00 AM
I just put Kewl covers on mine. They said on the driver's side to bend the right edge downward, and work it in around the braided fuel line that runs through the cover. Worked like a champ. The driver's side pivots at the top of the cover, and snaps in at the bottom. Really easy, and they will take a lot of flexing without breaking.
Aug 18, 2004 | 11:04 AM
Okay!!! So which one of you guys stole my tread? And just a little at a time no less.
