spilt milk
Old Aug 18, 2004 | 07:05 AM
Sleeper's Avatar
Sleeper
Default spilt milk
A friend I work with has an 04 ZO6 and when returning from the grocery, found that a gallon of milk had leaked from its container into one of his rear storage wells. Anyone know of a way to get rid of the odor? Thanks, Sleeper
Old Aug 18, 2004 | 08:42 AM
ACELR8N's Avatar
ACELR8N
Probably with vinegar and water, or maybe it's baking soda and water, oh damn, where's my wife when I need her.
Old Aug 18, 2004 | 08:54 AM
Patches's Avatar
Patches
It's really not a big deal to pull the carpeting from the rear section - takes just a few minutes. I'd definitely do that first to assess how extensive the spill was. Then I set about eliminating any milk from the carpet and insulation pieces that were involved. And, believe it or not, GM has answer for that part too . . .
Eliminating Unwanted Odors in Vehicles
GM Vehicle Care Odor Eliminator, GM P/N 12378554, US ACDELCO 88900909, Canadian P/N 88901678, may control or eliminate odors in the interior and luggage compartment areas of GM vehicles. This non-toxic, biodegradable, odorless product has been shown to greatly reduce or remove the following types of odor:
Objectionable smells of mold and mildew resulting from vehicle water leaks
Customer created odors, such as smoke
You may safely use GM Vehicle Care Odor Eliminator on fabrics, vinyl, leather, carpet, and sound deadening materials. You may also induce this product into HVAC modules and instrument panel ducts for the control of non-bacterial related odors.
Important
This product leaves no residual scent and should not be used as an air freshener.
This product may result in the permanent elimination of an odor and may be preferable to customers whose allergies make them sensitive to perfumes. This product may effectively remove odors when directly contacting the odor source. In cases such as water leaks, use this product with diagnostic procedures to first eliminate the primary cause of the odor. Then use further applications on the residual odor to permanently correct the vehicle condition.
How to Use this Product
Spray GM Vehicle Care Odor Eliminator directly or as an additive with carpet shampoo in steam cleaners.
Do not use on any interior surface that plain water would deteriorate, because this product will have the same effect. Also avoid letting this product come into contact with vinegar or any acidic substance. Acid-based products will hamper the effectiveness of GM Vehicle Care Odor Eliminator.
Instructions and cautions are printed on the bottle, but additional help is available. If you encounter a persistent or recurring odor, you may call to obtain additional information and usage suggestions.
In the USA, call 1-800-955-8591.
In Canada, call 1-800-977-4145.
© Copyright General Motors Corporation. All Rights Reserved.
I can also send you the procedure for removing/installing the rear carpet.
Old Aug 18, 2004 | 10:08 AM
stingray4me's Avatar
stingray4me
Don't cry over spilt milk.
Old Aug 18, 2004 | 10:09 AM
CAJUNY2KC5's Avatar
CAJUNY2KC5
Good one. Unless it's my car.
Old Aug 18, 2004 | 10:11 AM
BowtieDiva70's Avatar
BowtieDiva70
Old Aug 18, 2004 | 10:14 AM
tT-REXXX's Avatar
tT-REXXX
Default cookies
Everyone knows that the milk goes in the front and the cookies go in the back.What were you thinking?
Old Aug 18, 2004 | 10:31 AM
BowtieDiva70
Old Aug 18, 2004 | 01:08 PM
To spilt milk
