Headlight Actuator Problem?
Old Aug 18, 2004 | 10:57 AM
modrada's Avatar
modrada
Default Headlight Actuator Problem?
The passenger side headlight on my C5 opens up OK, but when it closes, it continues to run (grind) for approximately 5-10 seconds. Is this something that can be easily adjusted or is it something that needs complete replacement? Has anyone experienced this problem?
Old Aug 18, 2004 | 11:03 AM
Patches's Avatar
Patches
Sounds like the plastic drive gears are shot. Pretty common in these systems. If you investigate and find that's your problem, you can get metal replacements.
Edit: KernelDee has a better deal there. Definitely go with his source. Rodney is well-respected here.
Old Aug 18, 2004 | 01:14 PM
Cocked and Locked's Avatar
Cocked and Locked
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
I rebuilt my passenger side Monday. Check this thread I started and read each post. It will give you some needed info, including where to get the replacement brass gear.
Headlight Gear Rebuild Thread
Old Aug 18, 2004 | 01:29 PM
Oliver Sudden's Avatar
Oliver Sudden
You may have a bad headlight motor gear. The gears are made of nylon and will sooner or later break a tooth. I replaced the gears in my headlight motors with brass gears. Got them at http://www.rodneydickman.com/retail.html Look under the "Electrical" tab.
I fount the instructions for the replacement at http://forums.corvetteforum.com/show...light+actuator
Hope this helps
OS
To Headlight Actuator Problem?
