Column Lock By-Pass
Old Aug 18, 2004 | 02:18 PM
tds69tx's Avatar
tds69tx
Default Column Lock By-Pass
I recently purchased a CLB from Corvettes of Houston. The install went as planned but when I start the car, I get a message that reads "pull key, wait 10 seconds & restart". I called their servive dept but the guy could not give me any kind of answer for the fix. Anyone else had this problem??
Thanks in Advance!
TD
Old Aug 18, 2004 | 02:22 PM
dmtnt's Avatar
dmtnt
St. Jude Donor '03-'05-'06 & '12
Lol, I posted the exact same question 9 minutes before you. Does yours display the message every time? I got the message, pulled the key, then it started fine, but haven't had a chance to test further.
Old Aug 18, 2004 | 02:34 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
What year vette's do you both have? I have heard this is only a problem in 97-98 , but for 99 and up supposedly the CLB works great...most people here side with getting the CLB...I'm still undecided
Old Aug 18, 2004 | 02:39 PM
dmtnt's Avatar
dmtnt
'02 Z06. I also heard of this happening on earlier cars, but never '00+.
Old Aug 18, 2004 | 02:50 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
Old Aug 18, 2004 | 03:25 PM
Hiteck's Avatar
Hiteck
I installed my bypass from Corvettes of Houston a couple of weeks ago. Mine is a 99 M6. I haven't gotten the Pull Key, Wait 10 Sec message since I installed it. Works fine on my car. I'm knocking on wood right now too
Old Aug 18, 2004 | 03:30 PM
QuikZilver's Avatar
QuikZilver
Look at the directions that were included. There are a couple of fuses that need to be pulled, if this message comes up after installing the CLB. I can't remember which ones, as I am at work and the directions are somewhere in my garage. After pulling the fuses and waiting a minute, you put them back in and the message should be gone forever.
Come to think of it...there was a member in the Z06 section that posted a question about this part of the directions. I'll find the link and post it here.
Old Aug 18, 2004 | 03:36 PM
QuikZilver's Avatar
QuikZilver
Here is the link:
http://forums.corvetteforum.com/showthread.php?t=885332
In a nut shell:
The Insruction Sheet from Corvettes Of Houston States:
"if a "service column lock" or pull key and wait 10 sec. error is displayed, remove the ignition key and fuses No. 25 and No. 29 from the fuse panel. Wait 1 minute and replace."
This is after the install.
Old Aug 18, 2004 | 03:44 PM
dmtnt's Avatar
dmtnt
Thanks QuikZilver. I missed that part.
Boynton Beach?? I'm out west of you, Jog Rd. & Hypoluxo.
Old Aug 18, 2004 | 04:50 PM
QuikZilver's Avatar
QuikZilver
Actually, you are North of me...Boynton & Jog. Next week, I hope to have a bunch of stuff to install in my Z. I have two friends that I met through the CF that may be coming over for a "mod party". If you would like, I can let you know time, date and place. You could come over and hang out with us. Hopefully you won't mind that the other two drive C4's. :
Neil
Old Aug 18, 2004 | 05:07 PM
TorchRedRaider's Avatar
TorchRedRaider
Thanks in Advance!
TD
If after the fuse pull, you still have the issue, you might have to do this
http://forums.corvetteforum.com/show...p?p=1548076426
Old Aug 18, 2004 | 06:32 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
It still may not go away. My 98 A4 had the same problem with two different CLB's. I did all of the tricks posted here and still "Pull key..." every time. It would always start the second time but what a PITA to have that happen. It goes in for the recall next week as I had a brief column lock incident last Saturday. Since yours is an MN6, I hope the other suggestions work for you.
To Column Lock By-Pass
