side body molding removal
Old Aug 15, 2004 | 09:14 PM
chanderson's Avatar
chanderson
Default side body molding removal
I have a 2000 coupe and was wondering if anyone has removed the body molding and if they encountered any problems removing the adhesive. I am planning on removing the moldings, but I don't want to find out that the adhesive will be a pain in the but to remove.
Old Aug 15, 2004 | 09:32 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Yes, many here have ditched the BSM's, including yours truly. The basic technique used includes procuring some heavy fishing line and gloves to protect your fingers.
Wrap the fishing line around the fingers of each hand, then using the line stretched between them like a saw, cut through the double-sided tape. Applying heat via a hair dryer will make this significantly easier.
Then rub / peel / roll off with your fingers the remaining material.
Finally, buy some "3M Adhesive Remover" at Napa, follow the directions to remove the residue.
Some folks will warn (and I suppose it depends on the color of the car) that you may have a "ghost" image where the paint hasn't faded under the BSM. My car was 4 years old when I did it and this was not an issue for me.
Old Aug 15, 2004 | 10:08 PM
chanderson's Avatar
chanderson
Thanks dan. I had a 96 impala and I removed the quarter panel lettering and had some difficulty, but eventually it did come off. I suppose the bsm's adhesive is similar. My car is black and so was the impala and there was only very slight if any difference in paint fade. I will give it a try on the corvette next weekend. thanks for such a fast reply.
Old Aug 16, 2004 | 06:25 AM
Patman's Avatar
Patman
I had mine removed last week and it took over 4 hours! Because it's a 98, they were on there pretty good, and most of the adhesive stuck to the paint. So it took a while to slowly peel it off. But there is no evidence they were there, I had my friend with a detail shop help me out and he did an awesome job. Luckly the previous owner of my car kept the black paint shiny as new, so the paint under the BSM didn't look any different.
Old Aug 16, 2004 | 08:03 AM
lt1george's Avatar
lt1george
Default Bsm
Another member had a nightmare of a time because his door had been painted. Took them off and had to put them back on, so make sure dealer didn't do any paint work. Good Luck.Save the Wave.>George
Old Aug 16, 2004 | 09:18 AM
90 droptop's Avatar
90 droptop
I have done all 3 of my c5's with no problems. Leave the car in the sun and let it get nice and warm. I have always clayed the car after just to get the reamaining glue off. Then follow up with some good wax and away you go.
Old Aug 16, 2004 | 10:10 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Another one joins the non-BSM ranks!!
Old Aug 16, 2004 | 10:59 AM
vettenovice's Avatar
vettenovice
Just thought I'd ask...Are the BSMs really soooooo bad that you'll risk creating a mess (ghost image, etc.)? IMO, I think they look fine and also provide some protection from dings.
Old Aug 16, 2004 | 11:30 AM
Mike Mercury's Avatar
Mike Mercury
Are the BSMs really soooooo bad...
to some they are. It's all a matter of personal preference.
Old Aug 16, 2004 | 01:23 PM
Seems to be a common thing to do. The only problem you may encounter is with the paint under the molding not matching the rest of the panels due to sun fading.
Old Aug 16, 2004 | 02:00 PM
HHC5's Avatar
HHC5
The only way to go. The BSM really breaks up the beautiful body lines (IMHO)....to each their own.
Old Aug 16, 2004 | 07:43 PM
chanderson's Avatar
chanderson
I totally agree with you HHC5. I've seen them with bsm and without. The overall lines look very different without them...more of a sleeker look.
Old Aug 16, 2004 | 07:59 PM
-McTullis-'s Avatar
-McTullis-
We attempted to remove mine last week and it wasn't a pleasant experience. I have done this before several times and am fairly patient with it, but this time part of the clearcoat came off. Don't know why...allowed the adhesive remover to soak in, heated it up, and cut with some line. Cleaned off the area in the back towards the door handle first and noticed an indentation in the paint so i put them back on with 3M body tape. $30 down the drain. Oh well.
Old Aug 16, 2004 | 08:00 PM
blazeone's Avatar
blazeone
Mine came with BSM and I removed just as fast as I could.
Old Aug 16, 2004 | 08:02 PM
blazeone's Avatar
blazeone
That's a "roger".
Old Aug 16, 2004 | 08:05 PM
90 droptop's Avatar
90 droptop
I have done 3 cars ans NEVER put adhesive remover before.
Old Aug 16, 2004 | 09:26 PM
Shylor's Avatar
Shylor
I didn't use adhesive remover either. This is the first time I've ever heard of anyone removing them and the clear coat came off.
To side body molding removal
Old Aug 16, 2004 | 09:33 PM
Joe Diver's Avatar
Joe Diver
CF Enhanced Member
Cruise-In VI Veteran
St. Jude Donor '06
Oh Ya...that be me....search on BSM Removal Nightmare for my sad story.
Old Aug 16, 2004 | 10:54 PM
SamsBud
Guest
Posts: n/a
If you use the fishing line, you don't really need to "saw" the entire length of the BSM - just free up enough that you can get ahold of it, and you can gently pull it off using outward pressure.
It does take some time to get the residue off. Blisters have been known to happen, because you need to use your thumbs & fingers to roll of the excess goo....
Old Aug 16, 2004 | 11:47 PM
Shylor's Avatar
Shylor
That is probably what pulled off the clear coat. I sawed mine all the way with the fishing line method. I think this is the best way to do it. Then you can roll off any remaining adhesive that is on the paint.
