active handling question
Old Aug 20, 2004 | 01:36 AM
gillettij's Avatar
gillettij
Default active handling question
I went out and snotted my 'oo mil yellow six speed tonight.
I did kind of a hole shot around a corner. The first time I did it
I thought that my car had a fuel delivery problem because it kind of just fell on it's face. Later on, I took out my brother in law and did the same thing and the same thing happened, but he said that the active handling icon lit up. So then I turned it off and the result was was that which I didn't expect; the car was ready to do anything that I wanted and I was able to fishtail through a burn out. Is that what active handling does? It felt like the car was starving for gas with active handling, but turned of she would accept what I could give.
Anyway gimme some input on this please so that next I can beat the snot out of her and tear off some of that useless rubber on the back tires.
Old Aug 20, 2004 | 01:52 AM
GrayC5's Avatar
GrayC5
You need to be very careful out there on the streets with the A/H off. Some here have learned this the hard way. Might be better to try the Competitive Driving mode instead and save the "A/H Off" for the track. The Competitive Driving mode turns the T/C off but leaves the A/H on.
Old Aug 20, 2004 | 02:03 AM
gillettij's Avatar
gillettij
How do you select competitive driving mode?
Old Aug 20, 2004 | 02:25 AM
GrayC5's Avatar
GrayC5
It depends on the model year of your car and whether you have 1st or 2nd generation A/H. For cars through model year 2000 (I think) with 1st generation A/H, the car must be stationary with engine running. Push and hold the A/H button until "COMP DRIVING" appears in the DIC. For 2nd generation A/H, the competitive driving mode can be selected while the car is moving by pushing and holding the A/H button for more than 5 seconds. Again, the competitive driving mode turns the T/C off but leaves the A/H on. You may want to review your Owner's Manual for complete details on the system.
Old Aug 20, 2004 | 02:29 AM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
In your case you may need to be stopped to get into Competitive driving mode. With my '01 I can be stopped or moving to do this. To get into Competitive driving mode I would stop the car and once stopped press your A/H button and hold it for 5 seconds. After 5 second you should be in Comptiitive driving mode and this should be displayed in th DIC.
Old Aug 20, 2004 | 03:05 AM
BickyDhadwal's Avatar
BickyDhadwal
same thing used to happen in my 01 yellow vert...then i figured out the comp thing too...its amazing...but i never get on it anymore..not worth it i just leave trac on...ive learned from my mistakes
Old Aug 20, 2004 | 06:27 AM
dadsturn's Avatar
dadsturn
St. Jude Donor '08-'09
Just can't beat that jekyl/hyde button!
To active handling question
