Stereo Question
Old Aug 22, 2004 | 02:05 PM
USARMYTTT's Avatar
USARMYTTT
Default Stereo Question
I am posting this link here because of the limited exposure in the stereo section...Thanks in advance!
http://forums.corvetteforum.com/show...post1548107325
Old Aug 22, 2004 | 02:15 PM
lavoieste's Avatar
lavoieste
I have had that problem in the past and i was told that the AMPS have Thermal shut downs...AKA it gets too hot it shuts down so that NO DAMAGE is done to the AMP.
Good luck....lose the Vinyl cover!
Do you know stock speaker sizes for 99 Convert???
Old Aug 22, 2004 | 02:20 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
I used to sell audio equipment, so I can say, The shut down is preventative. It's good to at least know it works. The heat causes long term damage to the wiring, but that's normal (depending on use). I wouldn't sweat it. I mounted my amp against the rear panel. No ventilation problems. Hope this helps.
Old Aug 22, 2004 | 02:21 PM
USARMYTTT's Avatar
USARMYTTT
If you want aftermarket they are 6.5's in the front and I think 5 1/4 in the rear.
Old Aug 22, 2004 | 02:24 PM
lavoieste's Avatar
lavoieste
great thanks!
Old Aug 22, 2004 | 04:35 PM
navy99vert's Avatar
navy99vert
Cruise-In VIII Veteran
To Stereo Question
