Engine washing ?????
Old Aug 22, 2004 | 05:29 PM
Derf's Avatar
Derf
Default Engine washing ?????
Anything I should know before washing the engine and compartment?? I remember the C4 opti spark was a problem, any here? Thanks
Old Aug 22, 2004 | 05:49 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
I honestly don't cover anything..I spray some GUNK Citrus Engine bright on a warm NOT hot engine let it sit a few minutes..crank up the car and gently mist/wash off the dirt...I leave it running awhile after usually just close the hood and wash the car...never a problem
Old Aug 22, 2004 | 06:06 PM
yober1's Avatar
yober1
Cruising
washing the engine compartment is kind of risky, need too check the vette if the air intake is completly closed, it would be a bad idea to let the the engine suck in that water
Old Aug 22, 2004 | 07:31 PM
Cocked and Locked's Avatar
Cocked and Locked
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Sounds like a good method. Thanks
Old Aug 22, 2004 | 07:34 PM
Some have used Simple Green and then a light stream of water to do the trick. I have never washed my engine - just wipe it down every now and then after I was the outside of the car.
Old Aug 22, 2004 | 09:12 PM
YBNORML's Avatar
YBNORML
I saw a post a while ago that said NASA stopped using a similar product to simple green because of a deterioation to aluminum parts on aircraft. I'd reasearch it a little further.
Old Aug 22, 2004 | 10:44 PM
lt1george's Avatar
lt1george
Default engine wash
Never.
Old Aug 22, 2004 | 10:50 PM
raidersfan's Avatar
raidersfan
From: Spread The Virus!!!!!!! Opie and Anthony XM Satellite Radio
I would suggest just wiping it down with a rag with maybe simple green or another cleaner on it. and used compressed air to clean out the hard to reach areas. If you do use water, use a soft stream, don't go nuts and power wash it.
Old Aug 22, 2004 | 11:19 PM
FLACHUSNRET's Avatar
FLACHUSNRET
St. Jude Donor '11-'12-'13-'14-'15-'16
Default I vacuum my engine with my shop vac!
There is always a little dust and grit on top of my engine after a day of driving so I simply open the hood and vacuum off all exposed areas. It keeps the under hood area looking like new. I would never consider washing my Vette's engine. After vacuuming I wipe everything with a damp detailing towel. Of course this process only works if you start out with a clean engine, not one that 80,000 miles with no attention.
Products like Fantastic and Simple green are highly corrosive to alumnium and can discolor many items under your hood.
Old Aug 23, 2004 | 01:45 AM
motoracer's Avatar
motoracer
I cover the air intake filters. Spray the engine down with Simple Green and then wash with garen hose.
Carefull not to spray the intake plenum hard.
Then let the engine idle till it is dry.
I have been doing this for years.
I am curious about the simple green hurting the aluminum. My engine block looks fine.
Old Aug 23, 2004 | 02:30 AM
Big Jay E's Avatar
Big Jay E
We soak aluminum cylinder heads and blocks in full strength Simple Green to clean them. Doesn't hurt a thing.
Jay
Old Aug 23, 2004 | 07:38 AM
wrustywrench's Avatar
wrustywrench
I have always washed my engines....from my old mini truck , street rod and motorcycles. I spray simple green on a cold motor, and rinse with the pressure hose, use low pressure around important stuff. I have NEVER had a water related issue from wahing a motor. Most motors are fairly water proof. Washing helps you find oil seep sooner, keep dirt from building up and holding in heat. I use a turkey baster with a small hose attached to suck up the pooled water on the intake and in nook and crannies to keep it form crusting up..works great. I have never had a corrosion problem from washing , I make sure they are dry and spray SP100 corroson inhibitor on the engines twice a year. The motor is the heart, keep it clean.....inside and out
Old Aug 23, 2004 | 10:26 AM
BSiegPaint's Avatar
BSiegPaint
St. Jude Donor '06-'07
Simple Green is an aggressive cleaner - VERY alkaline, and if any happens to remain behind on an aluminum part, it will quickly degrade the material. You can see pits as quickly as overnight. If possible, find a pH neutral cleaner to use.
Old Aug 23, 2004 | 10:42 AM
Coyote's Avatar
Coyote
WOAH..... Well, I'd NEVER spray water all over my engine bay.. that's for dern sure. Now.. I do hand wash the components and vaccum out dust and such. I had an IDIOT spray my C4 engine bay down once and it screwed that car over and it was never right again. (Yes yes.. I know.. probably just the optispark..). I just can't see all the electrical components digging having water squirted on them.
Old Aug 23, 2004 | 11:03 AM
90 droptop's Avatar
90 droptop
I've used a diluted mixture of simple green for years. I just spray everything off with water very well and then take the leaf blower to blow the heavy water off and start and let it idle and run until dry. Never had a problem and my engines look brand new. To each his own.
Old Aug 23, 2004 | 11:13 AM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
Old Aug 23, 2004 | 11:14 AM
Vetteran's Avatar
Vetteran
St. Jude Donor '03-'05-'06-'07
I use my air compressor to blow out grit and such, then I use a damp
cloth and wipe everything down that I can get to. I don't use the
compressor everytime but I do wipe the engine down everytime I wash.
To Engine washing ?????
Old Aug 23, 2004 | 02:44 PM
VlackBette's Avatar
VlackBette
I use the mini cali-duster to clean out dust buildup in my engine compartment.
Works pretty good.
Anyhow, will water harm the belts?
Old Aug 23, 2004 | 03:34 PM
yellow01's Avatar
yellow01
40psi air does the trick every time
Honesly I have a compressor/tank from sears so I can set tire pressures and use air tools at home. I bought a little quick-release accessory kit, one piece of which is just a little trigger/air gun.
Set to 40psi and blow away It works very well unless you got something wet, such as in rain and then I just hand-wipe as good as possible.
The air stream is PERFECT for cleaning out the runners and indentations in the intake and around the injectors and coil packs. It's also great for the radiator area ... heck it just works great!
wit2pz's Avatar
wit2pz
I used plain water to rinse my engine yesterday. I had sand and salt water built up from my 4 rainy days at Myrtle Beach last week. I drove through standing water down there from Hurricane Bonnie, then got even more from Charlie right after. When I saw all the sand that had collected in the engine compartment, plus knowing the salt from the rain and the beach that built up, I HAD to spray it down. Gentle pressure for the most part, then wiped dry. No problems.
