Windshield wiper squirters leaking @ speed
I searched the archives for any mention of this problem and didn't run across anything. Has anyone else experienced this?
And yes, whenever I've gunned it... I see the tear roll up my windshield.
here ya go it was four years ago...a search brought this up:
There was a post here about using the check valve from Ford to cure it. It works very nicely! Get Windshield Wiper Fluid Check Valves (1 package = 2 valves) from Ford Motor Co.- #F8CZ-17A614-AA - $4.08 - any dealer will have it. Remove wiper arms (13 mm bolts under the snap off caps,
then wiggle and pull), cut the washer fluid tube under the blade assembly just before it splits to the 2 output nozzles, and install the valve (1 each side) with the check ball pointing towards the pump - i.e. away from the outlets, and press fit the thing back under the wiper arm prior to re-install. Nasty Ford part is invisible, and hammering the car = dry windshield. No big deal, I was just tired of cleaning up the solvent residue from the stuff.
One note from the service manual that was useful: before removing the wiper assemblies, turn the ignition to "accessory," turn wipers to slow intermittent, and turn off ignition when they are down (at end of cycle but not parked all the way down on the stops where they go to when you turn them off). Then use a piece of masking
tape on windshield on both sides to mark their position so that the reinstall is properly aligned.
Yes, there have been several threads on this here in the past.
I've been on the forum a couple years and I guess I missed all the other threads about the subject.
Although low on my priority list, I did want to see if I could find out what was causing this. Now I know.
Guess I still have to carry around that special windshield microfiber towel to clean it up when it happens... oh well.
I stopped and popped the hood...searching all over the engine compartment...
Good for 2 RWHP I believe.
...George
