LED Display Not Lighting
Old Aug 26, 2004 | 03:31 PM
klp's Avatar
klp
Default LED Display Not Lighting
My display for air/heater quit working. At night, they are very dimly lit, but I can't see the display during the day. The DIC, dash lights, and stereo LED display are all working fine. I haven't checked the fuses yet because I was assuming that the Radio display and the Environment display would be on the same one. Any ideas?
Old Aug 26, 2004 | 04:14 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Those things (display) have an internal fuse, but most of the time if LEDs burn out, they're burn't out. Similar scene. on a past radio, but the service guy told me the internal fuse was just as $$$ to fix as maybe finding a new one. Not sure on cost of temp display unit but, I'm sure you can research and find one online. Also post in PARTS and TECH section here, if you haven't already. Good luck. Hope this was useful. I hope someone has a better suggestion.
Old Aug 26, 2004 | 04:40 PM
klp's Avatar
klp
Very helpful. Thanks a bunch.
Old Aug 26, 2004 | 06:14 PM
I have read posts that say the lights on the control units either can't be fixed or cost way too much to do it. Check with Gene at the KarShop (forum vendor) and see what a used part would run you.
Old Aug 26, 2004 | 06:15 PM
klp's Avatar
klp
Will do. Thanks for the response.
Old Aug 26, 2004 | 06:18 PM
wit2pz's Avatar
wit2pz
Mine's done the same thing, but it seems to be intermittent. Off(dim) sometimes, bright other times.
Old Aug 26, 2004 | 07:26 PM
jim49tx's Avatar
jim49tx
Just had my AC/Heat Dual Head Unit replaced because the light burned out. It starts by dimming durning the day so you can not see it and then it just goes totally out. Mine when out completely the very morning I took it in.
This is very common. It cost my extended warranty 672 bucks but I had a zero deductable
You can not replace just the light..I ask the same question here a month ago.
Jim in Amarillo, TX
Old Aug 27, 2004 | 12:02 PM
klp's Avatar
klp
Thanks Jim. $672 is pricey, but it drives me crazy when something isn't working on my baby.
To LED Display Not Lighting
