Eric's Column Lock Unlocker/Bypass
Old Aug 31, 2004 | 07:38 PM
ericdwong's Avatar
ericdwong
Default Eric's Column Lock Unlocker/Bypass
I had my column lock up on me the other day, but I think I know why it happened. I parked on a hill in the grass in my yard, and when I got out of the car I hoisted myself out with the steering wheel and twisted it so it locked. Then the steering wheel locked up when I went to move the car. Following instructions from fellow members, I took apart the bottom steering column cover and whacked away with a rubber hammer and sure enough it disengaged.
Im not going to install a real CLB because 1) i dont need my car to get stolen/towed any easier 2) I've read alot about the CLB screw ups for a 97-98 3) I'm too cheap to buy a CLB
Soooo....I came up with my own CLB. I now keep in my car T15 and T20 torx bits so I can take apart the steering wheel, and I keep the rubber mallet incase I need to beat on the steering column.
Old Aug 31, 2004 | 07:44 PM
Patches's Avatar
Patches
So you now keep a column unlocking tool kit in the car handy for the thief?
j/k Eric. Just remember that a would-be thief could make use of those just as easily as you could so your first justification is partially null. I agree with your second reason that the CLB could create problems. Your third one is your preference.
Old Aug 31, 2004 | 07:54 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
If you have an A4 the pin will be removed and you won't have the problem again.
Ignoring the recall could cause its own problems. You can still install a CLB on a M6 even after they do the recall.
Old Aug 31, 2004 | 08:17 PM
ericdwong's Avatar
ericdwong
My car is a M6. I've read that on 97-98's the CLB can cause the BCM to go haywire because it doesnt supply the necessary voltage.
Also the torx bits wont help a theif steal the car any more. Banging the steering column only gets the column lock to unlock after it does not unlock WITH the key.
Old Aug 31, 2004 | 09:41 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
I dont think you have to worry about someone stealing Your car Eric
Old Aug 31, 2004 | 11:00 PM
Old Timer's Avatar
Old Timer
Old Aug 31, 2004 | 11:13 PM
Dave68's Avatar
Dave68
As I have mentioned previously, grabbing the steering wheel, either when entering or exiting the car is a recipe for future column lock. Many forum members who have had their columns lock have admitted to this behaviour and quite a few who never grab the wheel have mentioned that even though they are driving a 97-99 model, no lock-ups have occured. I drive mine daily and have never had a problem (after 3+ years).
Old Sep 1, 2004 | 04:31 AM
Hadn't thought about this method of unlocking the steering column. Hey, if it works .... I went ahead and installed the CLB - don't have to worry whether it will unlock or not.
To Eric's Column Lock Unlocker/Bypass
