I need some BSM removal tips!!
Old Aug 31, 2004 | 11:47 PM
GrandSportRob's Avatar
GrandSportRob
Default I need some BSM removal tips!!
I plan to remove my body side moldings next week..With the forum site not working well I can't do a search on it..I remember reading that I should heat it up and try to pull it back then use fishing line to saw through it..What do I clean the glue off the body with that won't damage the paint? Your tips are appreciated....
Old Sep 1, 2004 | 12:02 AM
ericdwong's Avatar
ericdwong
I actually used thin steel wire (aka, guitar string) cause fishing line wears thru too easy. Also make sure you wear gloves. Get goof off or similar style adhesive dissolver. Also have alot of patience. It takes quite some elbow grease.
Old Sep 1, 2004 | 12:45 AM
Shylor's Avatar
Shylor
I would use fishing line, less chance of harming your cars paint. I didn't use heat, just fishing line and wore leather gloves. As a section came off I put a rag between the molding and car body to give me some room. Taking your time should still only be around 30 minutes max for both sides.
Old Sep 1, 2004 | 12:52 AM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Some people have also used a hair dryer to heat up the adhesive which they claim will help with the removal of BSM.
Old Sep 1, 2004 | 04:18 AM
Some Goo Gone should do the trick on the adhesive. Good luck with the removal.
Old Sep 1, 2004 | 07:41 AM
rbl's Avatar
rbl
I hear allot of horor stories about removing them .... paint never looks quite right or the same. Beware
Old Sep 1, 2004 | 07:43 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
A hair dryer Not a heat gun, and some waxed dental floss
Old Sep 1, 2004 | 07:46 AM
sempi's Avatar
sempi
What ET said! Yep!
Old Sep 1, 2004 | 07:54 AM
Corvette SSX's Avatar
Corvette SSX
St. Jude Donor '08
That's what I've used on to remove them from several of my C5's.
Old Sep 1, 2004 | 07:57 AM
WolfeBros's Avatar
WolfeBros
St. Jude Donor '05-'06-'10-'11
Sorry but got to call on this one.
The only problem I ever heard of with removal involved a car that had possibly been repainted and the paint didn't match. This is a very common mod done by a lot of forum members with no problems.
I would like to hear of any horror stories. The rest of you BSM removers please get my back on this one.
Old Sep 1, 2004 | 09:24 AM
jw38's Avatar
jw38
St. Jude Donor '14,'18,'21
Here's what I did on my 04 Mag Red coupe and a friend's Torch Red 04 vert. Apply painters tape (Blue masking tape) above and below the BSM. Take a flexible putty knife and cover the end with the tape. Using a hair dryer, "warm" the BSM for a few seconds and then very carefully slide the putty knife under the BSM. As you do this, use your other hand to gently pull the BSM away from the car while, at the same time, you continue to warm the BSM with the hair dryer. I removed mine in less then 3 minutes with ABSOLUTELY NO damage to the car. I did the same with my friend's vert.
Old Sep 1, 2004 | 09:50 AM
Evil-Twin's Avatar
Evil-Twin
I only have one question ! your applying heat from a hair dryer with one hand, prying with a flexable putty knife with the other, and pulling on the molding with the other.
What about us people with only two hands!
Old Sep 1, 2004 | 12:27 PM
Joe Diver's Avatar
Joe Diver
CF Enhanced Member
St. Jude Donor '06
Yuppers...that was mine...the driver's door had been repainted at some point, so there was a very noticeable "trough" in the clearcoat because they didn't remove the BSM's when they painted...the paint matched okay, but that low area was completely unacceptable. Sad too, as the rest of the car looked like there was never anything there. Rather than spend a considerable amount to get the door fixed, I just put them back on.
http://forums.corvetteforum.com/show...oval+Nightmare
Old Sep 1, 2004 | 10:15 PM
MYtFineMag01's Avatar
MYtFineMag01
Default BSM removal
Just removed mine...took the baby to work on Friday and let her sit out in the sun... came home and it took me about 30 minutes to remove the molding...used Goop and a waxed piece of string... about two hours cleaning her up (lots of Zanio)... can not tell they were ever on... also removed the trunk emblem as well...and mine is a 2001..mag red
Old Sep 1, 2004 | 11:23 PM
GrandSportRob
Lots of great tips guys...i'll let you know how it turns out...
Old Sep 1, 2004 | 11:34 PM
Larry_Yerton's Avatar
Larry_Yerton
Here's the best tip of all........LEAVE THEM ON
To I need some BSM removal tips!!
