Can Any One Give Me The Gm # For The Engine Recall On The Oil Consumption Problem. They Are Doing A Oil Consumption Test Right Now. They Have To Add Oil At Least 10 Times.this Want Take Long Using A Quart Every 200 Miles
01 White Zo6
21000 Miles
01 White Zo6
21000 Miles
This has been a problem with C5's as well--Syn Oil suxs
I agree --- Castrol Syntec oil stinks. ExxonMobil filed a lawsuit against Castrol for claiming that its oil was synthetic when in fact it really wasn't. Castrol was using dino oil in the base stock for its "synthetic" oil.
01 White Zo6
21000 Miles
It's a shame they've burdened you with this "consumption test" BS. You might try doing a search and printing the MOUNTAINS of threads just here on corvetteforum regarding this problem.
I had it on my 01. My dealer was very professional about it. I had saved the receipts of each quart i bought and wrote the mileage (and they could see the recept date)...they at 1st wanted to do a consumption test...
I understood that they had to make sure my claim was valid...so i suggested they review the recepts, then swipe their finger around the tailpipe, rub a white rag on the back valence (had been awhile since i'd washed her), then pull a couple spark plugs....at which point they just took it in a re-ringed it with Napier-profile oil scrapers.
they did an excellent job. I put another 20k miles on her over two years...and NEVER had an issue. Consumption dropped from a quart every 300-400 miles to over 1500 miles.
Synthetics are the best lube you can buy...as long as the motor is designed for it....and unfortunately Chevy took a shortcut in '01. Good luck with it.
From: GOCC - Rebels Without A Clue Santa Barbara, CA
I think this is what you are looking for. Hope it helps.
Subject: Higher Than Expected Oil Consumption (Replace Rings and Engine Valley Cover)
Source: Chevrolet Dealer Technical Service Bulletin
Number: 01-06-01-023A
Models: 1999-2001 Chevrolet Camaro, 1999-2002 Chevrolet Corvette, 1999-2001 Pontiac Firebird, with 5.7L Engine (VINs G, S -- RPOs LS1, LS6)
This bulletin is being revised to add model years for the Corvette, information on the LS6 engine and parts information. Please discard Corporate Bulletin Number 01-06-01-023 (Section 6 - Engine).
My 2001 Z-06 just turned 20000 miles. It has never used any oil.
Just goes to show!
Dont quote me on this, but I believe the oil consumption problem is supposedly related to certain driving conditions/habits of some drivers and supposedly wouldnt occur under what GM considers to be normal driving conditions/habits. Extended low MPH/High RPM or constant low RPM conditions I believe if I remember an articale I had read awhile back.
mobil 1 is so cheap. so light and strong. so efficient. i use it on my hair. a certain amount of lube is lost at the ring/wall interface. i will add a lot of lubricant to that engine before i re-ring. IMHO. thx, johnny
That is all General Motors B.S. it's bad rings, not bad drivers. My 02 used a quart every 600 miles. I made them give me a new car.
Thats why I used alot of supposedlys. Guess I didnt word it exactly right. GM made the statements to infer that it wasnt a design flaw, rather something discovered by drivers driving in ways they didnt anticipate
