wheel sensor
Old Sep 2, 2004 | 01:08 PM
Xtreme Habbits's Avatar
Xtreme Habbits
3rd Gear
Default wheel sensor
I have aftermarket rims and one of the wheel sensors came loose. I brought the tire to a shop and when they remove the tire the sensor fell out. After inspecting the rim it looks like they put the sensor on with JB weld or liquid nail. What is the proper way to install the sensor?
Old Sep 2, 2004 | 01:16 PM
Ego-Trip's Avatar
Ego-Trip
Senior Member
CI 5-6-7-8 Veteran
What you mentioned is a common way of doing it on wheels that do not accept sensors in the common way. Usually they will be mounted with an epoxy.
As an alternative there are some huge "band clamps" that can be used to strap the sensor to the wheel. That is the way that HRE mounted the sensors in my wheels. Unfortunately one of mine also came loose but that was blamed on the place that mounted my tires.
Either method seems to be very effective.
Old Sep 2, 2004 | 01:39 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
I have custom wheels and the sensors are epoxied in and banded.
No problems in 2 years of running that way.
To wheel sensor
