Help!
Old Sep 3, 2004 | 05:06 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Default Help!
I have an '03 A4 C5 with about 25K miles. My DIC has lit up like a X-Mas Tree! In June I had a ABS/Traction Control Warning come up. I restarted the car a couple of hours later, warnings went away, no problem since. Since this past Monday, the same message and lights are on. They either come on immediately, or with 20 minutes of driving. I'm planning on taking the car in Tuesday for new weather stripping, so I'm adding this to my list. My questions are: should I be worried? I know this happened to another memeber and it turned out to be a corrupt program. Should I have them flash the old one and re-install new programming or am I asking for trouble? I use this as my daily. I need my car to be okay. Any wisdom from you guys/gals. TIA.
DAVE Q.
Old Sep 3, 2004 | 07:26 PM
CAJUNY2KC5's Avatar
CAJUNY2KC5
It could be a speed sensor in one of your wheels, but they should read the codes to determine what is causing it.
Let us know what they find and good luck.
